95 starter location???
Old Nov 14, 2001 | 09:54 PM
M.D.A.2's Avatar
M.D.A.2
Default 95 starter location???
Ok I'm an idiot who is trying to replace a starter using a JACK... Life really sux right now, but anyways.. Where is the starter?? I can't get totally under the car with the jack. I may run and buy some jackstands in a few.
Also do you have to remove anything to get to the starter??
Thanx,
A moron in trouble :confused:
Old Nov 14, 2001 | 11:26 PM
tommelton's Avatar
tommelton
Default Re: 95 starter location??? (M.D.A.2)
It is on the passenger side of the engine, rear of engine, bottom of engine, right beside the oil pan. :)
You may have to bend the transmission cooling lines out of the way. I am not sure how the pre-cats will affect getting the starter down.
Also, you should NEVER get under a car supported only by a jack. Repeat NEVER! Get jackstands, good ones, not cheap ones.
Tom Melton
82 CE
86 Z51 Coupe
[Modified by tommelton, 10:30 PM 11/14/2001]
Old Nov 15, 2001 | 06:41 AM
rnelson11's Avatar
rnelson11
Just removed mine during a clutch change. Easiest starter I have ever removed. Only two bolts and they go straight up into the bottom of the block. Just remove them and the starter slides straight back. Make sure you remove the positive cable from the battery because the big wire on the starter is always HOT.
Old Nov 15, 2001 | 09:14 AM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
Default Re: 95 starter location??? (95Vette&2000SS)
Mine wasn't all that easy to get out, took about an hour total. The shorter of the two bolts is tucked in under the edge of the cat heat sheild, kind of had to tap the socket past the heatsheild, then all was good to go. I slid it forward a few inches then dropped out. Trans lines had to be pushed over to the side ,but not by much.
Old Nov 15, 2001 | 03:29 PM
rnelson11's Avatar
rnelson11
Default Re: 95 starter location??? (Springer's 95)
Sorry, Took mine off while changing the clutch.....nothing in the way.
To 95 starter location???
