Hot Cam question
Old Oct 17, 2007 | 01:24 PM
dchildress's Avatar
dchildress
Default Hot Cam question
I have a 94 LT1 6speed. Basically stock except for K & N with open lid, Hooker shorties and Corsa cat-back. I am looking into a Hot Cam kit to add a little power.
Dumb question...do I have to reflash ECU after install?
Old Oct 17, 2007 | 01:25 PM
RRT vette's Avatar
RRT vette
most definitely.
Old Oct 17, 2007 | 01:29 PM
dchildress's Avatar
dchildress
Originally Posted by SniperC4
most definitely.
Thank you, I was not sure.
Next dumb question....will the Hot Cam raise the "red line" at all?
dumbest question....if so, can I put an LT4 tach face on to reflect new RPMs?
Old Oct 17, 2007 | 01:41 PM
RRT vette's Avatar
RRT vette
Perhaps a little if any. I don't think you will need the higher rpm tach gauge unless you want it for looks. You might want to have some other things upgraded while doing the hotcam (valves, springs, lifters, roller rockers, heads, ect.) It will also need a good, almost on spot, tune. Best would be to have it dyno tuned. Mine has a mail order tune and is ok, but when the engine is cold there is a low rpm "bucking" until the ECM is closed loop. This, I have read, is common with a cam upgrade before tune or not a great tune. A local tuner quoted me $500 for a dyno tune.
Old Oct 17, 2007 | 01:45 PM
dchildress's Avatar
dchildress
Thank you again. I was planning on doing the whole kit....cam, lifters, rockers, and springs...in addition to the Opti, water pump, and maybe a new radiator.
To Hot Cam question
