Cooling Fans
Old Oct 17, 2007 | 03:23 PM
rg951's Avatar
rg951
Default Cooling Fans
Seems like a simple question...but for some reason...i feel like I'm losing my mind....
When you turn on your car.....does the #1 fan come on automatically....or when it only hits a certain degree?
Then......the second one comes on upon reaching a higher temp (226?) or when you turn on the a/c.
Is this correct? I can't remember if my #1 fan came on instantly when I turned on the car...or only after it warmed up.
Old Oct 17, 2007 | 03:50 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Do a search....there must be a 100 threads on this.
Old Oct 17, 2007 | 05:26 PM
rg951's Avatar
rg951
Thanks for your help
Old Oct 17, 2007 | 05:35 PM
toptechx6's Avatar
toptechx6
I think what you may be noticing is the electric air pump, I thought it was the fan running on my car too when it is cold. Open the hood and take a look, I think you will see both fans are off on start up.
Old Oct 17, 2007 | 05:42 PM
rg951's Avatar
rg951
I just didn't know when fan #1 came on.
I just assumed (or thought) it came on upon start up.
Thats why I was wondering if it came on immediatly...or after a little bit.
Old Oct 17, 2007 | 06:01 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
When you first stat the car, neither fan should be running (UNLESS you have the a/c system on).
Some people may think it's not on, but if you have the electronic climate control it very well could command a/c as soon as you start the car (depending on what you have the settings at, and air temp.)
The cooling fans are not just controlled by the ignition key and sending power to them. They will not run unless certain parameters are met. There are times when you don't want them running (speed over approx. 35mph for example). At speed they will hinder airflow more than help it.
Old Oct 17, 2007 | 06:07 PM
toptechx6's Avatar
toptechx6
If the climate control is on as stated the fan could run even when cold.
Old Oct 17, 2007 | 08:00 PM
rg951's Avatar
rg951
I wasn't sure...but your explanation helps.
Old Oct 17, 2007 | 10:21 PM
AdoptAVette's Avatar
AdoptAVette
The 91 service manual explains it as:
*) if A/C is requested (this can happen in auto mode), the main fan (top fan) will turn on, but no aux fan.
*) if temp gets to 108C (226F) the main fan will turn on.
*) if temp gets to 113C (235F?) the main and aux fan will turn on.
*) if temp goes back to 108C the aux will turn off.
To Cooling Fans
