Normally Aspirated 500hp Stroker Possible?
#41
Received 3,043 Likes
St. Jude Donor '05
Emo, that cam will be totally liveable on the street on a motor your size. Cubic inches really tames out what appears to be a roudy cam on paper.
#42
Personally I think it is a good cam. There are many people here with much more experience etc in picking cams to match heads etc.
My cam works well for me using a 396, behive springs ported and polished factory LT1 heads etc. It idles well and gets up and goes real good too. Runs 11.'s all day through an auto with 2800rpm stall.
I have a 93 with Long tubes so I did change over to heated O2 sensors as they ran a little to cool and I couldnt get to closed loop. Now all is well, cam runs good for a Daily Driver, IMHO.
#43
St. Jude Donor '03 & '05
This link shows the innards in their 383/396 section
http://www.speeddemonmotorsports.com...engineLT1.html
#44
Just wanted to add,look at the new LS7,it makes 505 HP but its also a 427 cubed engine!
The LT1 can be made to perform,and stroking the engine or increasing cube size seems to be the best way to get there.The guys on here have tried their stuff and know it through and through.
Jake also brought up some good points.Keep the goal realistic and build it to where it can be done and perform.
#45
Does this cam "chop" more than a say a hot cam in a 350. I think I've had it with the shaky idle. People say the choppy idle in a stock LT-1 w/hot cam is mild. I have this cam in my 350, and it doesn't sound mild at all. Shakes the **** out of my passengers who think my engine is missing. Nice snappy throttle though and crisp accel from 2000 rpm and up. But I had it on a dyno and the horsepower numbers were embarassing. (240hp max at the rear wheels...... )
#46
It seems to me that the tide has risen in the horsepower arena. . . . with new Acuras coming stock with 265 hp. The 2008 vette is promising 600hp. . . .and every new sports car is in the 350hp and up range. What can I do economically to stroke my LT-1, with new heads and cam to produce max horsepower. Also,, if you can, mention what type of gears I would need for such a a beast and post any examples you might have.
That said, certainly these C4's can stand a boost if you want one. But you don't have to have 500whp to be faster than most cars you'll meet on the street.
#47
Yep, I agree. The Hot Cam - even though it has a catchy name (marketing) isn't much of a cam at all - IMHO
Jake
#48
Jake
#49
Aftermarket cranks with longer, 3.75" strokes abound these days. Years ago they were as rare as hen's teeth, but nowadays several companies sell them. A forged crank with the same stroke at 400 SBC came with is readily available. You can even get one that has a tad more stroke; a tad more than 3.75".
One of the problems is that once you go much over 3.75" in stroke, other changes have to be made; like rod length, piston pin hole location, camshaft clearance, etc.
That's one of the main reasons that stuffing a 4" stroke crank in our blocks is so problematic. You'll end up with shorter rods (negatively effecting your rod length/stroke ratio), pistons with very little skirt, a reduced base circle camshaft, etc.
Jake
#50
A 396 has a 3.875" crank. There are kits for these combos, as well as 4" cranks, with rods and the correct pistons included. While shorter rods are not required; most use 5.70" or longer, the correct ones are needed for clerance. There is some block grinding, and sometimes block-fill is needed.
#51
#52
TEA has a stage3 TFS lt1 head that supposedly flows like 300cfm @ .500 lift... with a good cam and 396 cubes you may come close! I believe a lt4 intake is required though.......
#53
TFS submitted a pair of CNC'd then hand ported LS2 heads to a head shoot-out and even those LS2's couldn't flow that. Just to put things in perspective, the TFS heads out-flowed the set that AFR sent to the shoot-out.
None of the five or six sets of heads flowed anywhere near 300 cfm @ .500. At .600, yea, but NOT .500. We all know that LS2 heads out flow LT1 heads. So 300 CFM at .500 is BS.
Jake
#54
I bet a big block stroker, i.e. 454 stroked to a 496 or larger with some nice heads and a lumpy cam could surpass 500 rwhp naturally aspirated. But that is going to be very hard to put in a C4, unless you plan on hogging out a lot of stuff. A small block would be a lot harder, but it still would be possible.
#55
**** the HORSEPOWER NUMBER !! IT'S JUST A NUMBER ON PAPER !!!!
Don't get caught up in the horsepower war on paper. A Z06 STOCK runs high 11s which is very good. A 400rwhp C4 with the right gears and tires also runs 11s I don't race on a dyno.
#56
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
#57
St. Jude Donor '05
Wouldnt it be nice if someone actually listened to this?
#58
No **** Good people get hung up on 500 horsepower 600 horsepower etc. all the time. They try to bassackwards calculate chp so they can have some big ******* inflated horsepower number to talk about. I knew a guy with a 700+ horsepower Supra and I whipped it's *** over and over and over with 440 go figure huh ?? It's not all about building the highest peak horsepower number you can, you have to live with the thing.
#59
Although I've learned to just ignore them, few things irk me more than threads that state "I'm going to do this, that and the other thing. How much HP will I have?" Good God, do I even need to say more? Figure out what your needs are, what you want to accomplish, do your homework and let the numbers fall where they will.
#60
I consider the ZZ9 and the Hot Cam as entry level, performance cams. It seems that many feel it's always necessary to defend their parts choice - It's like if they admit they made a wrong choice it's somehow demeaning and lessens their self-esteem. Must be an ego thing going on.
I, for one, chose a 58mm TB and posted that it was the wrong move. I went back to a 52 and became a happy camper. Had I chose 52 up front I would have saved myself a few hundred dollars. Bigger's not always better; live and learn.
Jake
Jake
