Crossfire Vacuum Line
Old Oct 20, 2007 | 12:19 PM
clevette's Avatar
clevette
Default Crossfire Vacuum Line
I just picked up an 84 project that someone gave up one. It has a new motor installed but idles at about 1400 rpms. I found a vacuum line off in the rear of the intake on the drives side. It is not for the brake booster. Has a hose fitting and points twards the firewall. Where does this line go?
Old Oct 20, 2007 | 05:37 PM
CFI-EFI's Avatar
CFI-EFI
For starters, on a "project" you are really going to need a FSM (Factory Service Manual). There is a strange looking 90° fitting that screws into the far left, real of the intake manifold. The threads for the fitting are much larger than you would expect for the hose size, and the fitting is a strange shape. If that is what you are talking about, the fitting takes a short (1" to 1 1/2") length of hose that has a plastic, three port (tee) check valve, on the other end. The tee takes a hard plastic vacuum line that disappears through the firewall wrapped up with a wiring harness for the HVAC controls. The other heads to the left side of the car and has a tee that heads, one to the cruise control, and the other to the vacuum accumulator (ball).
I hope that is the right fitting and that this helps.
RACE ON!!!
Old Oct 20, 2007 | 08:21 PM
clevette's Avatar
clevette
Thanks. That helps.
I Have the FSM. I was looking in the wrong part for the line.
Old Oct 20, 2007 | 09:47 PM
JLeatherman's Avatar
JLeatherman
Check the throttle shafts for slop. Any 84 with over 75k or so will develop slop in the Throttle-Body shafts and it will cause a ton of idle problems. Just a heads up. For a lot of good crossfire advice check out
http://crossfire.homeip.net
Old Oct 21, 2007 | 12:41 AM
clevette's Avatar
clevette
How do you fix worn throttle shafts? Bushings?
Old Oct 21, 2007 | 07:28 AM
JLeatherman
Yeah, you gotta send/take them somewhere that can do it. The aluminum gets bored a bit bigger and bushings are installed. A steel throttle shaft can only ride in cast aluminum so long before the hole starts getting bigger.
Old Oct 21, 2007 | 08:42 AM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
The rule of thumb on CF TBs is they wear out around 50k, but I've seen them worn out at as low as 29k original miles. There is no rhyme or reason on a time frame for wear...its just a steel shaft press fit into a cast body that will wear considerably over time and causes a large vacuum leak on any crossfire motor which is a very common issue.
When the TB wears, it makes it impossible to balance the TBs and will cause idle issues and others. Even if you get the balance perfect, as soon as you move the throttle plates the wear in the shaft hole will come into play again and the setting will be off and leak again.
The only real fix/solution is to have them bored on the shaft hole to true the hole and have them bushed and then they will be good as new...better actually.
To Crossfire Vacuum Line
