What weight oil???
Old Oct 20, 2007 | 03:08 PM
kowalski340's Avatar
kowalski340
Default What weight oil???
I would like to know what weight oil everyone is running in their L98s. especially the higher mileage examples. my 1989 L98 has 113,000 miles on the clock and runs great but I want to keep it that way! what does everyone think about me running 10w-40 with a K&N filter? or because I have increased bearing clearences should I go with a 20w-50? I will of course be using a full synthetic so thats not even a question thanks
Old Oct 20, 2007 | 05:49 PM
bogus's Avatar
bogus
10-30 is more than enough.
the tolerances haven't changed enough to warrant 20-50.
Old Oct 20, 2007 | 05:58 PM
c4cruiser's Avatar
c4cruiser
10W-30 will be fine for the climate in the LA area. 5W-30 would also be fine.
I seem to recall that at one point, GM specifically did not recommend the use of a 10W-40 oil in small block Chevy motors and they even stated that use of that specific weight oil would void factory warranties. I think this was in the 70's and maybe into the 80's.
Old Oct 20, 2007 | 06:04 PM
kowalski340
so no 10-40 then????
Old Oct 20, 2007 | 07:10 PM
VtVette's Avatar
VtVette
I seem to remember reading that the reason for this was there were problems with the 10W-40 rating back in the 70s/80s. Can't remember the specifics.
Old Oct 20, 2007 | 08:10 PM
KeyWestJack's Avatar
KeyWestJack
I thought the 10-40 was cool until I read some of the posts here. They made sense to me. Currently I am running 5-30 Royale Purple. Also I have been known to use Amsoil and Moble One.
Old Oct 20, 2007 | 08:15 PM
kowalski340
so what is the problem with the 10-40 I can see no problems with using a 10-40 in an engine with 113,000 miles but if anyone has an actual argument against it that would be great. also what is the oil capacity of a bone stock 1989 L98, 5 or 5.5 quarts??????
Old Oct 20, 2007 | 09:10 PM
VtVette's Avatar
VtVette
I don't think it's going to cause any problems for you. I just picked up 10W40 today for my 'vette. Don't know why I grabbed 40 instead of 30 but that's what I did. I'm not too concerned.
10W-30, 10W-40 I don't think it matters all that much as long as you keep it changed regularly. That's the key.
Old Oct 20, 2007 | 09:12 PM
Corvette Chris's Avatar
Corvette Chris
I'm running Mobil 1 5W30 in my 61000 mile '86 w/ Aluminum heads.
I'd try the 10W30 and see what your oil pressures are like.
Old Oct 20, 2007 | 09:38 PM
c4cruiser's Avatar
c4cruiser
There is probably no big deal in running 10W-40 in a motor with 113K on it, but it's not a weight that listed in the owner's manual. 5W-30 (shown as the preferred weight in my owner's manual) or 10W-30 are the two recommended weights and either can be used. You can even use a straight 30W oil if the usual ambient air temps are always above freezing. Unless you have already bought some 10W-40, the 10W-30 will work fine.
As far as capacity, the L98 uses 5 quarts with a filter change. You can use a slightly larger filter like the AC Delco PF1218 that was used on 350 cid V8's in light duty pickups and large cars. This filter won't stick out below the oil pan. It holds a full quart and the filter material is larger than the stock PF25.
Old Oct 20, 2007 | 10:16 PM
VtVette's Avatar
VtVette
Good info there. I have no idea what posessed me to buy the 10W-40 but I don't think it's worth the hassle to return it I'm just going to put it in. The oil cap on my '93 Chevy pickup recommends 5W-30 as well. Seems chevy recommends this weight for their TBI/TPI 305s and 350s.
Old Oct 20, 2007 | 10:50 PM
Demonic85's Avatar
Demonic85
I used 5W-30 Mobil Clean 5000, it works the best for me.
Old Oct 21, 2007 | 01:26 AM
GS4-LT1's Avatar
GS4-LT1
As long as your oil pressure is good stick with 5w-30 or even 10w-30. The molicules of 10w-40 have to stretch to far inorder to achieve there specific weight. 10w-40 is not as durable of an oil as the others and will be worn out sooner. I don't think you can even get a synthetic it 10w-40, can you?
Old Oct 21, 2007 | 01:47 AM
bogus's Avatar
bogus
Think about this... how does a bearing wear? It's hydrostatic... if it wears, that means metal is touching. that's bad.
Old Oct 21, 2007 | 01:59 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default Try 5W-30W
Try 5W-30W Mobil 1 or Royal Purple. These thin synthetic oils will work great and give you a few extra HP due to less internal friction.
Old Oct 21, 2007 | 02:54 AM
Carpenter's Avatar
Carpenter
New 383 Stroker Using 5W30(Mobile 1) I was concerned. Hot idle [200 degrees] showed only 7 -10 psi. (Off idle rpm showed maybe 25 +/-)
So I switched to 10W40. Now hot idle is 20 psi & off idle is 50 +[200].
I'm concerned now. With the 10W40 cold idle is 30+ psi. Cold off idle 60+ (Way too 'thick' I'm thinkin')
Will be changing to 10W30 this week to try to stabilize pressures.
Any thoughts?
Old Oct 21, 2007 | 03:12 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Any thoughts?
You better check your oil pump ASAP !!
To What weight oil???
Old Oct 21, 2007 | 03:15 AM
Carpenter's Avatar
Carpenter
Can you explain please?
Old Oct 21, 2007 | 09:23 PM
malc's Avatar
malc
Agree..
That does not sound good. My car with a 40kmile 1990 l98 stays between 40 and 70 lbs with mobil 1 10-30.
Old Oct 21, 2007 | 09:25 PM
bogus's Avatar
bogus
10 PSI per 1000 RPM.
If anything, I would be shocked if it was the pump... this sounds like a bit to much clearance between bearings and crank.
