From the past 24 hours of scanning the car, and reading the internet, BLM's do indeed affect the fuel ratio at WOT, it's only that the car disables learn mode.
I have seen much mass confusion about this.
misconceptions that the car goes to open loop during WOT.
plenty of other misconceptions about no fuel adjustment which just does not make any sense at all.
my car runs at 150 BLM all day, but the O2 sensor shows 860mv at WOT all day. That tells me it is not running lean. The computer has corrected it very well.
No O2 feedback = open loop. By definition.
How the BLMs are used differs from ECM to ECM. On the LT1 the stock programming uses them at WOT only when they are adding fuel. Many people modify the program so it ignores them completely at WOT.
Certainly haven't seen any mass confusion about it, at least in the LT1 world, as it's clearly documented numerous places.
1989 TPI motor, WOT, I see the o2 readings on my autoxray. they are about ~850mv. They move around slightly, so there is o2 readings at WOT.
and the autoxray shows CLOSED loop.
It does NOT jump back to open loop.
I now begin to understand the statement about "mass confusion" since you seem to be massively confused...
Which is irrelevant to whether the car is operating in closed loop.
Which is relevant to whether the car is operating in closed loop, if you don't understand the difference between "the closed loop flag is set" and "the car is operating in closed loop."
Again, this stuff is all FAQ. Don't want to believe me, go search any tuning forum.
well not exactly, NB 02 readings are not accuratte. I have made some comparisons to my LM-1, and 880's would be somewhat comparable to approx. 12.5. Stock tunes that I have seen for 87's were set to achieve approx. 12.8 past once past 1600rpm.
Using a 165, 727/730 ecm, pe is a 'special condition' as some will debate as "open loop". When entering PE (if the tune is close) it will then lock the blm/int. at 128. It does use a table (power enrich vs rpm) and bases the calculation for afr. on the table and the last blm 'seen' before entering PE to try and achieve the desired afr.
ok genious, why would you throw out the BLM adjustment at WOT ?
and it takes more than 02 feedback to move to closed loop.
Actually, BLMs DO affect WOT operation. If BLM is > than 128 at point ECM goes into PE, ECM will enrich further than the WOT calculation should be. However, fueling in WOT, which is Open Loop, is only calc'd. NB O2 does not affect WOT operation. That's why BLM is "locked" and learn is disabled once in PE mode. O2 feedback affects fueling after certain parameters such as temp and tps% are met.
