CFI lid removal?
Old Oct 20, 2007 | 11:22 PM
pipe's Avatar
pipe
Default CFI lid removal?
I went to remove the top lid on the crossfire manifold and removed the bolts along the outside edge and it still won't come apart. What am I forgetting to remove to get it off? Pipe
Old Oct 21, 2007 | 12:21 AM
brian84's Avatar
brian84
there are some bolts that go thru the tb units into the lower intakemalafold base? I know there is atleast 1 in each, maby 2 in each tb
Old Oct 21, 2007 | 09:11 AM
pipe's Avatar
pipe
How do I get to them? Pipe
Old Oct 21, 2007 | 10:13 AM
CFI-EFI's Avatar
CFI-EFI
The TBs are held onto the lid by three bolts. If you will notice, the two female threads that receive the bolts holding the air cleaner base to the TBs, are hex shaped. Those are two of the three TB bolts. The third is at the rear of the TB. The hex portion is to remove and install those two (per TB) bolts. The one outer TB bolt for each TB threads into the intake manifold base and sandwiches the lid between the TB and the base. Two more bolts and you've got it.
RACE ON!!!
Old Oct 22, 2007 | 07:24 PM
pipe's Avatar
pipe
THANK YOU GUY'S I found em unbolted em The top plate came right off then I had access to the rest of the intake bolts removed em and gave the lower intake a smack with the hammer and it came right off. THANKS AGAIN Pipe
To CFI lid removal?
