Service ASR
Old Mar 25, 2010 | 01:30 PM
  #41
Fast Cop's Avatar
Fast Cop
With no code for the TPS I am not going in that area till I can rule out everything else.
Are you still driving the car? Any other issues other than just the Service ASR and ASR Off lights?
I have read several threads about the Service ASR/Service ABS but all of those issues deal with other codes. All was working well till 2 days ago.
This past winter I had the car out on several days and went to areas with ice and both the ASR and the ABS worked fine.
Oh well, this is the first issue I have had in over 3 years with the car so I guess that its time to pay the pipper.
Old Mar 25, 2010 | 02:23 PM
  #42
ccs96's Avatar
ccs96
St. Jude Donor 06-'07
I haven't driven it in months, but have started it several times. I have driven a while with this problem without ill effect, just no ASR, didn't try the ABS though.
Old Mar 25, 2010 | 07:16 PM
  #43
aboatguy's Avatar
aboatguy
Have you datalogged it to see whats not normal...could rule out TPS....
Are wheel sensors working?
Mike
Old Mar 25, 2010 | 10:39 PM
  #44
Red Rocket's Avatar
Red Rocket
Dealt with the service ASR issue for months. Lost .3 and 3 mph at the track with the throttle being effected under acceleration. The problem would not show up on the dyno with the car strapped down. Still dyno'd with correct hp/tq.
Ripped out the ASR, wrote off using cruise control again, and saved five LBS in weight. Ended up putting in a F body throttle cable. Picked up the .3 and 3mph the following week at the track.
Old Mar 26, 2010 | 04:24 AM
  #45
toptechx6's Avatar
toptechx6
Not sure if this will help, but I found it on another forum so will post the link.
http://www.corvetteactioncenter.com/...abs/index.html
Old Mar 26, 2010 | 11:47 AM
  #46
ccs96's Avatar
ccs96
I forgot to mention that one of our club members w/ a 96 LT1 had this problem, I just don't know if his "service ASR" light came on after moving the vehicle or while it was still, anyway, his problem was a front wheel sensor.
Again, my Service light comes on before the car has moved, even if it's in neutral, it will come on as soon as you barely depress the throttle.
Old Mar 26, 2010 | 03:55 PM
  #47
Fast Cop's Avatar
Fast Cop
The codes I pulled did not have any wheel speed sensor codes. Only the 65 and 71. Lookinh at the FSM I can see the 65 setting if their is an internal problem with the EBCM. I followed all the charts in the FSM and everyting is pointing towards changing the EBCM.
I am trying to get my hands on a breakout box with the adapator for the ASR to valadate the troubleshooting I have already done. The proper resistance and volts register for the ASR actuator box so I am leaning towards the EBCM, but prior to spending that type of money I want to make sure.
P.S. Everything in the FSM states I can still drive the car without any problems only thing I will not have is ASR.
Old Mar 26, 2010 | 05:44 PM
  #48
ccs96's Avatar
ccs96
Good luck on finding a break out box. If you do, borrow it, I think they are big money. If you do get one cheap let me know I'll rent it from you.
I can drive mine w/ no problem, just as you say, no ASR.
Old Mar 27, 2010 | 10:57 AM
  #49
Fast Cop's Avatar
Fast Cop
I should have access to a breakout box next week. In the meantime I am doing a little more searching.
This morning I checked all codes. Did not get the 71 but still have the 65. Started up and no Service ASR or ASR Off light. Cycled through the switch and ASR cycled from off to on without any problem.
Backed out of the driveway and as soon as I hit the gas the Service ASR and ASR Off light came on. Punched the gas and lots of wheel spin (and a little smoke from the tires, that was fun).
Decided to test ABS to make sure all is well. From 45 mph I got down hard on the brakes and the ABS kicked in without a problem. During the ABS event the ABS Active light came on. All is well with the ABS.
Got home and had my coffee and donut, no cracks about cops and donuts.
Went out to check a few more things. Unplugged the connector at the ASR motor unit just in front of the PCM. Turned the ignition to the run position and the Service ASR and ASR Off light stayed on. Plugged back in and turned the ignition to run and the Service ASR and ASR Off light worked normal by comming on for approx 2 - 3 seconds and than going out.
Turned car on and still no problem. Cycled ASR Off and On via switch all ok. Push on the gas and once it gets about 1,000 rpm's the Service ASR and ASR Off lights come on. I am about to go back out and pull codes again to see what I get. More to come.
Old Mar 27, 2010 | 11:51 AM
  #50
Fast Cop's Avatar
Fast Cop
OK I just went out (coffee and donuts done) and pulled codes from my last run. The only code that keeps returning is the 65. Since clearing the codes yesterday the code 71 does not come back so I will go with the fact it may have been an old history code. No way to tell as with the method I am using to pull codes the FSM states they will all show up as H codes with the exception of the C12 which will always display when reading codes.
Si its down to the 65.
After clearing once again I started and all was well till I pushed the gas at which time the 65 set again and Service ASR and ASR Off light came on.
I pulled the cover off the ASR motor and will check that and see what I come up with. More to come.
Old Mar 28, 2010 | 09:12 AM
  #51
Fast Cop's Avatar
Fast Cop
I checked the resistance on teh ASR motor and did not get anyting. Per the FSM I did the reset of the ASR motor and measured the resistance and again nothing. Per FSM I performed this test 3 more times with the same results.
I believe I have narrowed it down to the ASR motor, but I am going to wait till I have access to the breakout box to confirm this as I do not want to just throw parts at it (that can get expensive very fast).
As soon as I get the breakout box and check the whole ASR system I willlet you know what I found out.
Old Mar 28, 2010 | 08:17 PM
  #52
ccs96's Avatar
ccs96
Old Apr 20, 2010 | 11:02 PM
  #53
BOOMGUY's Avatar
BOOMGUY
Default Anxious to here more
I had my service ASR light come on yesterday within 5 miles of the house after a 600 mile weekend. Did not seem to have any throttle response symptoms.
However, at the same time I got an intermittent SYS flashing in the fuel consumption area accompanied by a flashing SECURITY light.
I am looking forward to hearing the results of further trouble shooting by FAST COP.
Old Apr 21, 2010 | 11:27 AM
  #54
ccs96's Avatar
ccs96
Check your battery, I had a weak battery once and had the same thing happen.
Old Apr 21, 2010 | 01:10 PM
  #55
BOOMGUY's Avatar
BOOMGUY
Default Possible battery issue
Thanks for the tip, I'll check it.
The battery is 1.5-2yrs old though and since it came on after about a 250-270 driving leg, I am not sure that it would show low voltage at that time.
It started right up this morning after I checked some of the electrical connectors and topped up the brake fluid which really wasn't low.
Was able to run the revs up over 1500 a few times without any complaint or symptom.
As soon as we get a decent weather day again I'll take it out to see what happens.
Old May 1, 2010 | 04:27 PM
  #56
Fast Cop's Avatar
Fast Cop
Default Update, Problem Solved
Well I got around to completing the fix on my 96 vert with Service ASR code 65 today. I was going to fix it weeks ago but between vette pros sending the wrong part and than the following week spending the weekend at Talladega Superspeedway for the race I was not able to get to it till now.
After using the breakout box and the EBTCM adaptor I went throught the FSM diagnostics for a code 65 and all came up OK and pointed to the problem as being the EBTCM.
Went to work searching for a used part as I was not about the pay $800.00 for a new one. Found one.
Removed the old EBTCM (took only 10 minutes) today and installed the new one. Problem solved. The code 65 did not set and the Service ASR and ASR Off lights did not come on while driving.
I took the car to a dead end road to test out the system. With ASR Off it was smoke tires and donut time. With the ASR On the TCS worked as designed.
With every project I take on with my vettes I gain more confidence and am ready to take on the next one.
Old May 1, 2010 | 07:10 PM
  #57
toptechx6's Avatar
toptechx6
Thanks for the update, that is a step many forget once their problem is solved.
To Service ASR
Old May 1, 2010 | 07:31 PM
  #58
BOOMGUY's Avatar
BOOMGUY
Default EBTCM location
Is that the box mounted high up next to the cowl above the battery? I ask because in my FSM it indicates that is the ECM but doesn't seem to identify the EBTCM anywhere.
Since I wrote my post I have pulled the codes and have a 41, 32 and 72. I believe that it is the 72 that is giving me the "SERVICE ASR" light.
Old May 1, 2010 | 09:19 PM
  #59
ccs96's Avatar
ccs96
Behind the driver's seat.
Fastcop--
Glad you got it fixed, I guess I'm next.
Old May 1, 2010 | 11:05 PM
  #60
Fast Cop's Avatar
Fast Cop
Fastcop--
Thanks. If you need to use the breakout box and the EBTCM adaptor let me know and we will see what we can work out.
Do not buy a new EBTCM as they are $800 new. Use the auction site and you should find one for under $200.
