LT1 Swap
Here is the problem. The car starts right up but stops after about 3-4 seconds. I thought the VATS might be the problem but again I programmed it out. The engine runs a little rough and I have spark and fuel (not sure the how much pressure though but I am waiting on the fuel pressure gauge to come in) and I just changed out the gas and the fuel filter (had been sitting for a long time) and decided to try some water treatment just to make sure. Well the car starts right up, I can pump the gas and it reacts instantly but then stops no matter how much gas I give it.
I blocked off all vacuum ports for trouble shooting and tried the propane trick but nothing seems to help.
I had put the heads and intake back on about a month ago and followed along with the book while adjusting my rockers for valve lash but was thinking that perhaps I put them on too tight. Was also thinking that the opti might be going bad but it was running fine when I had the engine in my '94 Vette altough the engine has been sitting for about 2 years now. But like i said, I seem to have good spark.
Any toughts or recommendations would be great.
Thanks for any help
Dave
But - More likely - Fuel. Sounds to me like the oil pressure switch "takeover" of the fuel pressure relay isn't happening. Try just jumpering the relay and thereby Force the pump to stay running - see if that "cures" it. It's possible that the pressure switch isn't signaling the relay to stay closed. The ECM doesn't Hold the fuel pump relay On after the motor fires up - the Oil pressure switch does that... At least that's how the circuit is supposed to work on the L-98 cars - I'll guess (again - not real familiar) that the LTx cars are the same way. It's a GM thing...
Sounds like the dang VATS but I programed it out.
As for the oil pressure switch, the one on the back of the engine behind the intake manifold is the one you are talking about right, the only one I know of, is new and plugged in.
Any other inputs anyone.
Dave
At the time I was running a 700r4, converted my own factory harness and all was great. When I got my '94 Vette out here she had high miles on here so I pulled the LT-1 out of the '81 and put into the '94 since I wanted to do more work on the '81 and she would be down for awhile. Well my landlord is going to sell the place, I am going to Fl for training for 3 months then straight on deployment. I am running out of time here.
Well anyway I took the OBD I computer I used to have in the '81 and put into the '94 to data log. The dang thing wouldn't read. Took forever in a day, several failed attempts and aborts. Finally got one good read from it and it turned out that the VATS was enabled. How the heck was it enabled when I disabled it before. Either way after that one read I couldn't read it anymore.
Gave up on that OBD I for now and reprogrammed my '94 OBD I. Took out the VATS and nothing. Same symptoms. Starts for 3 seconds, sounds pretty good then dies and the fuel pump stays on for 2 seconds.
Well I got my fuel pressure guage today and I will try that.
On the side note. The engine was sitting for about 1.5 years so I am wondering if the OPTI is bad. Hawaii does get pretty humid. Has great spark while running but just dies which I guess sounds typical of a bad OPTI.
