Upper radiator support
Old Oct 23, 2007 | 11:02 PM
arandy's Avatar
arandy
St. Jude Donor '08
Default Upper radiator support
How the **** do you get the 7mm screws out from the sides of the upper radiator support on a 95. I could have changed 8 early C4 radiators in the time I have in this martin frogger.
Old Oct 23, 2007 | 11:22 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
It's a bitch. Be patient. I worked on it for days. I would go out, get a few turns, give up, go in, go back into the garage the next day....etc..
The bottom two are easy, the top ones are a bitch.
I was told to switch them around when re assembling the radiator, so next time it's easy.
Old Oct 24, 2007 | 06:21 AM
arandy's Avatar
arandy
St. Jude Donor '08
ttt
Old Oct 24, 2007 | 11:54 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
The pass side ones can be reached fairly easily without removing anything
The drivers side you have to remove that pump thats down there
I reinstalled all of them from the other way to make it easier next time
You just have to reach up the air intake to the radiator
To Upper radiator support
