1984 automatic shifter knob
Old Oct 24, 2007 | 12:37 AM
Nocall4it's Avatar
Nocall4it
1st Gear
Default 1984 automatic shifter ****
Will somebody please tell me how to get the push button shifter **** off the shifter? Thanks
Old Oct 24, 2007 | 03:42 AM
1BAV's Avatar
1BAV
Cruise-In IX Veteran
Default Shifter **** removal
Hey, it's pretty easy. All you need is a small screwdriver (flat tip) and a snap ring removal tool. Take your small screwdriver and gently pry up on the sides of the button. Walk it out by prying on each side a little at a time. There is a retainer on each side that sticks down in to the **** that helps hold it in. Once you have gotten the button out, look down in the top and you will see a snap ring down in the ****. Once you remove the snap ring the **** will simply slip off the top of the shifter. Simply reverese the process to re-install your ****. HS
