VATS or what?
Old Nov 16, 2001 | 10:25 PM
Frank C's Avatar
Frank C
Default VATS or what?
Hey, last night the 91 started and stalled. It would crank but would not start. This is the second time this has happened. The first time it restarted after 15 or so minutes. Last night I left it and went to dinner. 3 Hours later I returned and it refired like nothing had happened. Is my problem this VATS thing? I tried putting the key in and out several times and also rubbed it (don't ask) but nothing helped. Da....Frank
Old Nov 16, 2001 | 10:48 PM
Black 'n Blue's Avatar
Black 'n Blue
Default Re: VATS or what? (Frank C)
If it cranks, its not the VATS. Sounds more like a fuel or ignition problem.
Old Nov 17, 2001 | 01:08 AM
jfb's Avatar
jfb
Next time it cranks but won't start, check for spark , and then check the fuel pressure at the shrader valve on the injector manifold.
To VATS or what?
