SCCA solo racers
I'm thinking of starting to run that event in my 94 next year
Race on!
If you have never ran Solo 2 then that is a real good idea. You will learn alot running a "stock" car for a year and then go from there. It also gives you a good base for the care to know what to improve on and if the changes you make over time work or not.
If you want to be competitive you will want to spend the money for good tires and upgrade the brakes a little. If you are just out to have fun and not really about being competitive then you do not need to spend money on stickey tires BUT I still suggest that you flush the brakes, replace the lines (braided) and use some hawk pads.
The most important part of running SCCA or NCCC events is to HAVE FUN and talk with the other racers, you will learn ALOT from them.
I ran FS in a Camaro for 2 years all over Indiana and some in Michigan and they never said anything about it.
They did get pretty pissed when they found the illegal sway bars that I put the GM tags on.
I played stupid and siad that it must have been that way when i bought it
You asked about fun; It's a lot more emotional than just fun. Each minute of racing carries a whole lot of living in it.
I learned on 16 year old gatorbacks too. My husband kept saying "learn how to drive the car on old tires". But the car had no grip and it was a horrible sport for me coming in close to last at most events. If I had it to do again, that's one piece of advice I would not have followed. Tires changed it all for me.
good luck next year.
It covers a lot of info for you. SCCA has added cars in our classes that are very hard to compete with. However, all C4s can have the LT4 engine as the LT4 is in our class. I have a few mods and I run in B Street Prepared. After a full year of trying to compete I found that working all day for 3-4 thirty second runs got a little much. The fun is in the people you meet and those short runs. NCCC is much more Corvette friendly and you get much more seat time. Oh, TIRES< TIRES< TIRES>
Subman
I have always looked to improve myself from the last time I was out. Some of the guys I race against have been doing SCCA events since they were 16, while I have been running for 2 years. So I take that into consideration. I'll ask a lot of questions and have learned alot in two short years.
Alot of people will tell you tires tires tires. While that may be true a mild alignment for autocross/street driving enabled me to knock 2-3 seconds off my runs.
Once you go out for an event be prepared to get hooked!
HAVE FUN!
For Stock: Tires: Kumho, Hoosier DOT's, vary pressures to suit
Alignment: Max neg camber in front
1.5 neg camber in rear
one full turn of front toe rod on each side to
increae toe out from zero toe position.
1/8" total toe in at rear
Shocks: Significantly increase rebound control on rear shocks
Increase bump on front shocks
Misc: Add shims under sway bar mounts to adjust how fast
bars respond
Adjust corner weights to equalize cross weights. Rear
spring rod adjustment.
Just the tip of the iceberg. Go out and try it. You'll get hooked.
Ex DP Spridget, Corvette SS, BSP, ASP driver.
Larry
Carl Johansson
PS 2 day auto X this weekend at castle AFB - last of the year - gates open at 7:30 - on saturday - so you'll get there on the right day even! I'll go for sure saturday - haven't decided about sunday yet!
Be there or be whipped!
