hit a bump, engine running rough
Old Oct 30, 2007 | 08:44 AM
combustables's Avatar
combustables
Default hit a bump, engine running rough
Hi all,
I had my 86 vert literally humming then I hit a pot hole last friday and the car suddenly started running rough like it's on 7 cylinders. This happened immediately upon hitting the damned pot hole. I quickly checked the plug wires and they all seem plugged in just fine. The distributor is not loose and the wires into the distributor are connected solid.
WTF? what else could cause this? Could an electrical component go bad after hitting a pothole?
Lee
Old Oct 30, 2007 | 09:22 AM
Sam Lam's Avatar
Sam Lam
Push on each injector connection to be sure the impact did not dislodge the electrical connector to the injector. If this does not solve your problem, remove each injector lead one at a time and see which lead (when removed) does not create a change in the idle. This will give you and indication that it is related to a cylinder or some other issue. Got to start somewhere and do the simple stuff first
Old Nov 1, 2007 | 07:40 AM
combustables
Thanks Sam. I'll try messing around with the inhector wires this weekend. I didn't think about that but is sounds very reasonable. Great picture of your kid (I assume) behind the wheel. Start em off early :-)
Old Nov 1, 2007 | 08:52 AM
Corvette Chris's Avatar
Corvette Chris
Feel down each of your plug wires. I had something very similar happen to me in my '86. Car was running great, came to a stop sign to make a right, made the right and it was instantly down on power.
Probably spent the better part of 3 hours troubleshooting -- plug wires were the first thing I checked, albeit not too well. Tested the injectors and everything else, came out fine. My neighbor who is also a car guy came over. He started like the plug wires and found one that had just barely rubbing on something. Swapped it out with a different wire and voila.
I felt like an idiot..
Old Dec 8, 2007 | 05:58 PM
Slalom4me's Avatar
Slalom4me
Originally Posted by leefarah
Hi all,
Did you try adding gas line anti-freeze?
While, as has been pointed ou in other threads, it is unlikely that bouncing
through a pot hole would cause the timing chain to skip a tooth or damage
a distributor, perhaps water at the bottom of the tank rose up into the
fuel pickup tray and was thus drawn into the fuel line.
Commercial products like those sold at service stations or BG Fuel System
Drier #280 are safe to try adding to the tank. I don't have any bottles
on hand to check whether isopropyl alcohol or methyl hydrate is the
current principal ingredient in these products but I have used both for
gas line antifreeze purposes. Isopropyl alcohol is available from pharmacies.
You do not need to add much. A couple of ounces in the tank will
make a difference if water in the injectors is actually the problem.
Old Dec 8, 2007 | 06:54 PM
Yellow2015's Avatar
Yellow2015
Any codes thrown? Check electrical connections ie: injectors, MAF sensor, relays etc.
Old Dec 10, 2007 | 05:59 PM
QZRBLU's Avatar
QZRBLU
2017 C4 of Year Finalist
C'mon over and I'll hook it up to my Diacom+ Sorry, VA is a long way from Tucson.
It sure sounds 'dead' on that little video. Did you ever hook up a timing light to each plug wire? Might tell you which cylinder is failing.
Mick
Old Dec 10, 2007 | 07:25 PM
toddalin's Avatar
toddalin
Make sure that all of the electrical connectors (weatherpacks) are in tight and none of their wires have pulled out. Our '91 broke an electrical weatherpack plug "keeper" (the plastic tab) such that the plug could slide out just enough to loose contact and put the car in "limp" mode.
Fri--in dealer took three hours to diagnose, but I refused to pay for more than one! They were swapping out parts while I kept saying "probe the computer," which they finally did and instantly saw the code.
Old Dec 10, 2007 | 11:05 PM
combustables
Hi All,
Thanks for everybody's help and advice.
so far, I tried unplugging then replugging each injector electrical wire one at a time while the car was running and the problem remained unchanged. Rough idle and shaking badly.
I listened to each injector while disconnecting and reconnecting the electrical leads and I could hear them clicking loudly when connected and silent when disconnected.
I replaced all plugs, plug wires, dist cap and rotor cap.
I put a timing light around each plug wire and got the light strobing on every one.
No codes at all.
I checked all electrical connections in the engine compartment, ie: maf, iac, mat. I even dropped the ECM from under the passenger dash footwell and checked all those connections.
I checked fuel pressure. 42 in key on and 39-40 when running. It held up to 30 psi 30 minutes later.
I retimed the engine to 6 degrees BTDC as the VECI label says.
no change. Hard start and needing to feather the gas pedal for several minutes until the engine warms up then it just idles somewhat roughly and shaks during idle.
http://www.labib.com/runningbad.wmv
I'll be lifting it to look underneath for something glaringly obvious and will be back to report. We had 3 inches of snow on the ground until yesterday so please forgive the lapses between postings.
Lee
Old Dec 11, 2007 | 10:28 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I feel bad that you haven't found the problem yet but I feel even worse that you are working out in the cold. Does the car run well enough to get it to a garage where they can put it on a scanner? Maybe if you find which cylinder or cylinders are weak you can narrow your search. I just can't imagine what hitting a pothole could do to cause this, if that was the case my car would never run right with Illinois roads the way they are. Did you check the maf internally for broken wires?
Old Dec 11, 2007 | 10:36 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
I would check the O2 sensor and connections next
Old Dec 11, 2007 | 10:39 AM
kalister1's Avatar
kalister1
That sounds like a vacuum leak?
Old Dec 11, 2007 | 10:49 AM
stram8777's Avatar
stram8777
This is going to sound dumb, the VERY same thing happened to me in my '98 Camaro. Have you Catalytic Converter checked out. I never replaced it I just beat on it a little with a rubber mallet. The best explanation I got was the bump knocked loose some of the cones inside the cat which blocked flow through the cat and caused the power lose and inability to idle.
Let me know if this helps.
Old Dec 11, 2007 | 11:14 AM
Midnight 85
This could very well be it, does the engine idle a bit higher now than it did? Check the vacuum ball up by the drivers side headlight and the master cylinder connection and even a possibly cracked brake booster. By the time you check all this you'll be too darned cold to do any more.
Old Dec 11, 2007 | 11:58 AM
cdnguyred88's Avatar
cdnguyred88
Since the rest isn't getting you anywhere.....In my '88, I hit a bump in the road and my Car almost died like it was running on 5 or 6 cylinders. As I pulled over I hit a small bump and the Car ran fine. Hit another and all the Dash lights turned on and Car died. I pulled the Computer behind the dash pad and started the Car, tapped the box and Car stalled. I also hooked it up to be scanned and there was no signal most of the time. I replaced the ECM with a "new" one from GM ($100 cdn). That was about 6 years ago and been fine ever since, something about the circuit board according to GM.
Old Dec 11, 2007 | 12:55 PM
ZumZum's Avatar
ZumZum
It could even be something as simple as a fuel filter. The bump may have dis-lodged some crud from your tank.
If that's the case, you could probably still get the proper pressure to your rail, just not enough volume of fuel.
A filter is only $5 or $6 dollars and is cheap piece of mind.
Old Dec 11, 2007 | 04:01 PM
GIMMESOME's Avatar
GIMMESOME
How did you check the MAF?Did you disconnect it while it was running rough?Did it make any difference?It sure sounds like a damaged MAF sensor,but it should throw a code,but maybe not.The unit is pretty delicate,is the tiny wire in it still intact?
Old Dec 12, 2007 | 01:17 PM
rick lambert's Avatar
rick lambert
I think you're on the right track getting that puppy up in the air.....and taking a good look.
To hit a bump, engine running rough
