Cam Suggestions
Old Oct 31, 2007 | 07:41 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Default Cam Suggestions
Here's what I'm doing. I have an 86 with iron heads. I bought an engine out of a 90 to get aluminum heads and a roller cam. I plan on going through the engine this winter and putting it in my car. I have an Accel superram and 1.6 roller rockers. I plan to stay at 350 cid. Not sure what cam to use. A roller that will work with the 86 distributer and pass smog every 2 years. I was thinking the GM LT4 hot cam, but not sure it will work with a distributer. The duration looks like it would have a decent idle with enough lift to pull to 5500-6000. Waddaya think?
Thanks, Paul
Old Oct 31, 2007 | 07:47 PM
cv67's Avatar
cv67
St. Jude Donor '05
Kind of OT, but you wouldnt have a bother named Bobby would you from R.I.?
Old Oct 31, 2007 | 08:07 PM
1990dtgL98's Avatar
1990dtgL98
St. Jude Donor '10-'11-'12-'13-'14
I'm doing a superram/heads/cam upgrade this winter also, and have 1.6RR on the car already.
Seems the consensus here is the Lingenfelter 219 cam would work, and a few people have also used the Comp Cams 276HR "503" cam.
I think i'm going to go with the Comp 503 as mine.
Old Oct 31, 2007 | 08:17 PM
0Paul Ruggeri
Former Vendor
No, no brothers. Ruggeri is a fairly common Italian name, 'specially munx dim freakin' stugots on da East coast
Paul " Paulie Da Wrench" Ruggeri
Old Oct 31, 2007 | 09:29 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Ruggeri eh? Any relitives in Lyndhurst NJ? Any relatives that may be radio personalities under "stage names"
Anyway, I have the super ram and I went with the Lingenfelter 219 as that is what Lingenfelter says is supposed to go with the intake.
Hey, they are the engineers, they know better than I do.
I don't think I want to second guess them And, BTW, my lingenfelter cam came in a Comp Cam box, so comp Cams grinds the cam for Lingenfelter.
Old Oct 31, 2007 | 10:05 PM
1990dtgL98's Avatar
1990dtgL98
Where do you want peak power to be?
The 219 cam is nice, but don't peak as high as a different cam.
Old Oct 31, 2007 | 10:27 PM
jsup's Avatar
jsup
The super ram is not a high RPM intake, so to put a cam with higher RPMs than the super ram is designed to operate at, causes a mismatch and possible dead spots.
Old Oct 31, 2007 | 10:36 PM
1990dtgL98's Avatar
1990dtgL98
Though I have seen 230 degree cams dyno with a SR and make good torque while still running up to a peak HP at 5800-6000RPMS
Old Nov 1, 2007 | 11:40 AM
0Paul Ruggeri
Former Vendor
I need a fairly broad power band, nothing too "peaky". Does anyone have the specs on the Lingenfelter 219 cam?
No relatives on the East Coast. We're all here in sunny California
Old Nov 1, 2007 | 01:41 PM
cv67's Avatar
cv67
St. Jude Donor '05
219/SR should pass out here and will be very driveable...You have a pm
Old Nov 1, 2007 | 02:09 PM
vader86's Avatar
vader86
Get the 219
To Cam Suggestions
