Powershift 1-2 worth it?
Old Nov 17, 2001 | 06:00 PM
ericcer's Avatar
ericcer
Default Powershift 1-2 worth it?
I have not tried it at the track yet but it would seem that I would get to much wheelspin if I tried a 1-2 powershift. I already do the 2-3 and 3-4. I have street tires and 3.91 gears.
Old Nov 17, 2001 | 08:09 PM
jay17's Avatar
jay17
Default Re: Powershift 1-2 worth it? (ericcer)
Fill me in on how you guys power shift?
Old Nov 17, 2001 | 08:23 PM
KLLRVET's Avatar
KLLRVET
Default Re: Powershift 1-2 worth it? (jay17)
You can gain a couple of tenth's on the dradstrip powershifting in all of the gears. The way it is performed is the keep the gas pedal pinned and quickly push in the clutch and shift to the next gear. This takes a lot of practice to be performed properly.
Tony
Old Nov 17, 2001 | 08:55 PM
MDL-01C5's Avatar
MDL-01C5
Default Re: Powershift 1-2 worth it? (KLLRVET)
And let out or side step the split second the shifter is locked in the gear, depending on how far you have to let out the clutch before it engages the driveline, sometimes you will already be leting off the clutch just an instance prior to getting it all the way in gear, its extremely fast, precise and very useful and beneficial when done correctly 1-2 is fairly simple, 3-4 is the toughy for first timers, you'll get it ifyour well quainted with your vette!! good luck
chris :D
Old Nov 17, 2001 | 09:13 PM
ericcer's Avatar
ericcer
Default Re: Powershift 1-2 worth it? (MDL-01C5)
Are you guys saying you don't get to much wheelspin where it would hurt ET on the 1-2 powershift using street tires?
Old Nov 18, 2001 | 02:58 AM
fade_to_black's Avatar
fade_to_black
I would say it is worth it ...you will get wheelspin but it will still be quicker, although it may not seem like it.... :cheers:
[Modified by fade_to_black, 12:58 AM 11/18/2001]
To Powershift 1-2 worth it?
