93 Keyfob
Old Nov 1, 2007 | 11:21 AM
rumblin red's Avatar
rumblin red
8th Gear
Default 93 Keyfob
Does anyone know if possible and how to make the 93 keyfob 'normal' press door locks/unlocks door, press hatch, hatch opens.
Eliminate the walk up un lock/walk away lock
Old Nov 1, 2007 | 03:15 PM
Travis93's Avatar
Travis93
With the fob in range (doors unlocked) hold the door button down for about 5 seconds. The locks will cycle (lock and unlock) to let you know the mode has been changed.
Old Nov 10, 2007 | 01:19 PM
rumblin red
8th Gear
When I do this, This ONLY turns off the Walk up/walk away feature, and cannot then use the door button on keyfob as lock/unlock function
Rumblin Red
Old Nov 10, 2007 | 01:39 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Rumblin Red
The C4 key fob or PKE (Passive Keyless Entry), does not work like a normal key fob. I do not believe it will not do what you want it too.
You can turn the system off, so it won't lock/unlock the doors as you walk up/walk away. But in that mode, you would have to manually lock the doors and then use the key to unlock when you came back.
Old Nov 14, 2007 | 02:57 PM
rumblin red
8th Gear
Thanks for the reply-That is what I was afraid of. Is an aftermarket keyfob an option, or does this require quite a bit of bolt ons to the car for sensors to hit the locks and hatch?
Thanks again for the help!
291,000 miles and STILL rumbling along!
Rumblin Red
To 93 Keyfob
