Hi out there. The power window motor went out on me in my 94 and I have followed the great advice on the forums about getting to the motor and regulator. I'm stuck on getting the glass out and was told that a factory service manual has some good info on how to get the glass out so I can remove the motor. The weather is turning fast where I live and I want to store the car away for the winter this weekend (hopefully with the window up). I purchased the motor and the regulator but I know I don't have enough time to procure a FSM in time for the weekend. Can anyone help me out with getting access to those pages that give instruction on how to remove the door glass? I would gladly paypal a few bucks to you for your time.
Tool Required: J 22055 Window Retainer Nut Wrench (or vise grips)
Remove: Trim panel, water deflector
Scribe location of window pads before loosening then loosen and move pads away from window.
Remove inner mounting panel.
Connect side window switch.
Position window regulator to access window nuts and window stop guide.
Disconnect side window switch.
Remove window nuts and window stop guide using above tool (or vise grips).
Scribe location then loosen upper regulator bolts.
When removing window from door use openings on inner edge of door to clear studs on window.
Remove window from top of door.
Transfer parts as necessary.
Good Luck!
Thanks a bunch! I will try it out. I think they failed to address what to do with that black metal rod that is on the right side of the drivers side door attached to the top and bottom of the door with 2 bolts and the plastic piece that is attached to the window that travels along that rod. Any thoughts?
FSM didn't address those parts but if I remember when I was working on mine, I gently moved those arms out of the way and used a lot of tape and paper on the glass so as to from scratching it up. There's not a lot of room to work, not a fun job. While your in there consider replacing the water seal on top of the door, you have to drill out the rivets.
Hi again. Have you been able to manually raise the window up any? My motor died when it was all the way down making it almost impossible to remove it off the left bolt that holds the glass to the frame.
