What spark plugs
Old Nov 1, 2007 | 09:21 PM
MassaRusty's Avatar
MassaRusty
Default What spark plugs
I am looking for suggestions on spark plugs and what to gap them at for a 94 stock engine lt1 with the basic vortech kit. I suppose it has whatever the boost the base stock kit comes with. I just got the car this week and I haven't gotten a boost gauge yet. I use the NGK TR55s on my C5 and I am pleased with them. The vortech instructions say to use the stock heat range plugs, but most people seem to like to go to the TR6 (one step colder). Should I use the stock TR55 or the colder TR6? What should I gap them at?
Old Nov 2, 2007 | 01:14 AM
Mo_Bandy's Avatar
Mo_Bandy
I normally gap around .035 you could probably go a little wider. Like some things it is subjective with the type of wires and ingnition you are using. I'm using Iridium plugs...
I would run at least one step colder...
Welocme, and hope this helps
MO
Old Nov 2, 2007 | 10:17 AM
mn_vette's Avatar
mn_vette
For a stock vortech kit TR6's should be good, if you ever step it up try the NGK BR7EF's.
Old Nov 2, 2007 | 11:06 AM
MassaRusty's Avatar
MassaRusty
Thanks guys. I will try the TR6s when I get ready to do what looks like a nightmare spark plug change.
Old Nov 2, 2007 | 06:59 PM
Mo_Bandy's Avatar
Mo_Bandy
If you have shorty headers I found it easier to pull them from the bottom of the car...
If you have the stock manifolds I found it easiest to get to the driverside by removing the center section of the fenderwell using a long extension . I use a length of rubber hose to start the plugs to keep from potentially cross threading them.
Like MN_vette I'm using the BR7's also but i'm using AFR heads so I use the gasket type vs. the tapered used in the stock heads.
another consideration would also be to look into a water methanol injection kit, that will allow yo to reagain some timing as well especially with the stock compression.
Mo
Old Nov 3, 2007 | 07:11 PM
AIS's Avatar
0AIS
Former Vendor
From: www.alcoholinjectionsystems.com info@alcoholinjectionsystems.com Phone: 1. 801. 447. 2559
Have questions about using water methanol injection on your Corvette and the benefits it has to offer, be sure to contact A&A Corvette and ask to speak with Andy.
www.aandacorvette.com
(888) VETTEPRO
To What spark plugs
