Timing procedure help
Old Nov 2, 2007 | 08:55 PM
KeyWestJack's Avatar
KeyWestJack
Default Timing procedure help
The FSM says to look at the engine information label for my 90 L98, no luck it is gone. If you have that information I would appreciate your assistance. The manual says to disconnect the ECM (the four prong connector I think) connection. I do that and the engine won't start. Where am I going wrong. Thanks Jack
Old Nov 2, 2007 | 08:58 PM
mseven's Avatar
mseven
you will need to disconnect the est located in main wiring conduit near the brake booster (brown wire), the sticker all states setting base timing @6* in drive.
Old Nov 3, 2007 | 09:23 AM
KeyWestJack
Thank you for your assistance. Have a great weekend, Jack
To Timing procedure help
