Intake manifold advice
Old Nov 3, 2007 | 10:45 AM
87FIREREDRAGTOP's Avatar
87FIREREDRAGTOP
Default Intake manifold advice
Hi all, I am installing a new intake and need some advice. I have a zz4 crate motor installed in my 87. I am installing a nice Accell Super Ram on it with a 58MM Billet accell TB. What I am looking for is injector size. Is bigger better or will it flood the motor. Right now I am using accell 24LB injectors. On another note, my heads do not have the heat bypass hole for the EGR valve, is leaving the EGR in place(smog) going to hurt anything or should I have it deleted from the chip? Thanks in advance for anything you have to offer.
Old Nov 3, 2007 | 10:50 AM
87FIREREDRAGTOP
Here are the engine specs. Nothing internal has been changed with the exception of the addition of roller rockers.
ZZ4 350 Tech Specs
Block Part Number: 10105123
Block Type: Cast iron with 4-bolt main caps
Bore x stroke (in): 4.00 x 3.48
Camshaft duration (@.050 in): 208 degree intake / 221 degree exhaust
Camshaft lift (in): .474 intake / .510 exhaust
Camshaft Part Number: 10185071
Camshaft type: Steel hydraulic roller
Compression ratio: 10:1
Connecting Rod Part Number: 10108688
Connecting rods Type: Powdered metal steel
Crankshaft Part Number: 12556307
Crankshaft Type: Forged steel
Cylinder head Part Number: 12556463
Cylinder head Type: Aluminum; 58cc chambers
Displacement (cu in): 350
Engine Name: ZZ4 350:
Engine type: Chevy small-block V-8
Ignition timing: 10 degree BTDC @ 800 rpm 32 degree total @ 4000 rpm with vacuum advance disconnected
Maximum rpm: 5800
NOTE: Distributor with melonized steel gear MUST be used with long blocks and partial engines with steel camshafts, or engine damage will occur.
Piston Part Number: 10159436
Pistons Type: High-silicon aluminum with offset pins
Recommended fuel: 92 octane
Rocker arm ratio: 1.5:1
Rocker arms Part Number: 10089648
Rocker arms Type: Stamped steel
Valve size (in): 1.94 intake / 1.50 exhaust
Old Nov 4, 2007 | 08:41 AM
JackDidley's Avatar
JackDidley
24s are fine for a ZZ4. I have a ZZ4 cam in my 87. Pretty mild cam.
Old Nov 4, 2007 | 09:43 AM
87FIREREDRAGTOP
Thanks for the info. I was thinking the same thing. Just wanted a second opinion.
Old Nov 7, 2007 | 08:11 AM
ZylaRace's Avatar
ZylaRace
That big TB won't do anything but lighten your wallet.
Old Nov 13, 2007 | 06:48 PM
cruiserto's Avatar
cruiserto
Default injector size
for proper fuel injector size ....google "fuel injector size calculators "
Old Nov 14, 2007 | 09:04 AM
87FIREREDRAGTOP
Handy tools. Looks like the 30's would be better. Thanks
Old Nov 17, 2007 | 01:27 AM
TPI's Avatar
TPI
The 58mm TB is too big for a 350 cu.in. It will kill your low end tork. My 86 with 1.6 roller rockers, and a super ram ran much stronger with the stock TB than with a 58mm.
Injector flow(lbs./hr) = (HP X BSFC)/(#of injectors X 0.8)
BSFC is 0.4 to 0.6 so use 0.5, and a reasonable approximation of flywheel HP
To Intake manifold advice
