pre 94' with vented opti..question
Old Nov 4, 2007 | 09:42 AM
sonomacrew01's Avatar
sonomacrew01
Default pre 94' with vented opti..question
Where did you connect the vacuum hose? I might have made a mistake by splicing the brake booster line. Could this cause a vacuum leak?
Old Nov 4, 2007 | 10:58 AM
Red Dwarf's Avatar
Red Dwarf
Here's an article from C/F that shud help......
http://www.corvettefever.com/howto/16758/index.html
Old Nov 4, 2007 | 12:39 PM
NotoriousC4's Avatar
NotoriousC4
From the factory, the vacuum is sourced from a fitting in the intake manifold. I doubt sourcing it from the booster hose would cause a problem but it shouldn't be necessary.
Old Nov 4, 2007 | 03:42 PM
STL94LT1's Avatar
STL94LT1
I used a T-fitting off one vaccume line on the driver's side of the intake.
To pre 94' with vented opti..question
