hi maknushiver,
thanks man for the confirmation that it is a roller block,cool.
so this i piece rear main seal block is what i need then to suit my 1991 vette then for a rebuild yeah ??
im shivern now.
thanks alot
tyson
I see that you won it Glenn.
Be aware that the block is a later model Mexican block. It uses slightly different oil galley plugs for the 3 in the front of the block. They are metric.
Kinda amazing that block went for $300 out there. (or down there, or under, or whatever). I couldn't give away the same exact block a few months ago.
hi guys,
you mentioned that this block is made in mexico (wogland) so does that mean that it is sh*it then,poorly made,poor materials ??
also r.e the oil gallery plugs, will they be a problem too find ??
what else can you tell me about the block ?
thanks
tyson
it sounds like i should just give this block a miss then ??
what do ya reackon ??
thanks
tyson
No but I would ask question first before you pay shipping.
Check Just Parts mag for US parts importers in WA.
What you want is the more common Vortec truck block; roller cam and 4 bolt mains.
Used in 96-2000 pickups and Mercruiser inboards.
hey rod,what should a good second hand vortec block cost roughly any way ?
also if i were to buy a vortec block,does that mean when its time to buy new aftermarket heads i would need to buy them to suit vortec heads only ??
thanks
tyson
tyson
Vortec block is same as L98 except 4 bolt and more common in Oz.
Any SBC head will fit
The Vortec head fits the same as a normal SBC head just has different intake ports and intake bolt pattern (8 bolts not 12) requiring a Vortec only intake manifold.
I paid A$1000 for a complete dead Vortec and sold the heads for $600
Could try Chevpower : (08) 9459 7811 has used blocks
possibly Ivan at West Coast Chev (08) 9444 3577 can help
