I need studs that are about 1" longer than stock to mount my new brake kit.
Wich of these will fit?
The knurl length of diameter varries, and im notsure what I need?
Brand: ARP
Product Line: ARP Wheel Studs
Part Type: Wheel Studs
Wheel Stud Style: Press-in
Thread Size: 12mm x 1.50 RH Knurl Diameter: 0.558 in.
Underhead Length (in): 2.600 in. Knurl Length (in): 0.275 in.
Quick Start Nose: Yes
Quantity: Sold as a set of 5.
Notes: Designed to fit Lexus IS300 applications
Brand: ARP
Thread Size: 12mm x 1.50 RH Knurl Diameter: 0.579 in.
Underhead Length (in): 2.750 in. Knurl Length (in): 0.300 in.
Quick Start Nose: No
Quantity: Sold as a set of 4.
Notes: Designed to fit Mazda rear 1994-2005 applications
Neither of those will fit the Vette. They need a .509 knurl. ARP 100-7713 are 3.25" long overall and 100-7708 are I believe 2.75 long overall. Both are 12mm x 1.5 thread.
not sure of the part #'s but ARP does have the sizes mentioned
Use this GM part# 22551491 The stud is 76mm long with about a 14mm dog point on the end. I use these with 18mm spacers on some 5 spokes. The part # is "disguised" in the GM Performance catalog in the Olds engine parts section.
Very easy install, just nick the head on a grinding wheel 30* and they will clear the backside with no problem.
I sent you a PM also! Sent you a newer PM with a link to a snapshot!
Call your local GM dealer & tell them you want the wheel studs from a T-1 Kit. They fit from 84 - 2004 at least. That is what I used, sorry I don't have the part #.
FWIW The GM T-1 studs are longer than the ARP ones, mostly due to the unthreaded tip on the GM version.
