2-piece timing cover
Old Nov 7, 2007 | 08:33 AM
LD85's Avatar
LD85
Default 2-piece timing cover
What brand works with a factory small style water pump? Actually I havea Flowkooler but it looks liek a stock design
I don't want to spend $150+ or $250 for a 2-piece cover.
But some of them claim to require a spacer to "clear" the small pump,
Old Nov 7, 2007 | 09:50 AM
steven mack's Avatar
steven mack
I have a Cloyes with roller cam button on my 85.They sell them with out cam button also.
Old Nov 7, 2007 | 11:53 PM
BigLee's Avatar
BigLee
i had one of the inexpensive Summit brand stamped steel 2-pc. covers on my 86. it was pretty tight, but cleared enough without needing any kind of spacers on both the stock, and Edelbrock waterpumps...
its a really nice feature to have, especially if you like to experiment with different cams, or cam timing alot...
i glued the gasket to the cover, and used a non hardening sealer like "Hylomar" on the block side of the gasket, and re-used it several times, witout leaks...
the cover would always pop off without tearing the gasket, and
i would just re-apply a thin coat of Hylomar to the gasket, and re-install the cover.
Old Nov 8, 2007 | 04:49 PM
eguyett1985's Avatar
eguyett1985
I have the Cloyes Aluminum cover with the built-in roller button and an Edelbrock water pump and they fit but I did have to slightly grind two of the cam cover bolts on the timing cover and change the back plate bolts on my water pump to button head allens but no other clearence issues beyond that.
Old Nov 9, 2007 | 04:44 AM
LD85's Avatar
LD85
Thanks guys, I was hoping for the style that lets you change your cam.
They are either cheap or crazy expensive.
Old Nov 9, 2007 | 07:31 AM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Larry I think the 3-piece allow cam changes, I know my 2 piece Cloyes allowed timing changes but not cam changes. So be sure you get that clarification before buying.
Old Nov 9, 2007 | 09:42 AM
GRX's Avatar
GRX
I have the Comp Cams 2 piece, pricey but very convenient, and made right...fits perfect. I think they came out with a three piece after I got the two piece.
Old Nov 9, 2007 | 07:49 PM
LD85's Avatar
LD85
Yep, the Cloyes is nice but I'll wait for a Comp Cams 2-piece or a 3-piece to pop up on ebay
To 2-piece timing cover
