Right now I have a freshly rebuilt Jasper motor with a cast crank, and hypertenuic "speed-pro" pistons.
What I was wondering is if in the future, I decide to go with a supercharger, will that cam (224/230 at .050, .54x/.55x lift, 112LSA) will work well with a blower?
Also, how much do you think the bottom end can take? It has 4 bolt mains, but doesn't have forged internals, just cast/hypertenuic.
With lower compression you can push more boost before causing detonation. Detonation must be avoided or you will brake your pistons. Go to www.blowerworks.com and read all of their info on supercharging and tuning. I don't think your cam numbers matter much except that the supercharger magnifys your power, so a higher HP motor will benifit more than a lower HP motor from bost. My LT4 procharger kit came with a 4 1/2 lb. pully.
hypereutectic piston and boost are a bad mix especially with the compression ratio you have .get detonation a few times and guaranteed you will break a piston those pistons are known to start cracking, then they fail.if your going to put a s/c on keep your compression ratio between 8.5-9.0 to1 max.build it right the first time ,trust me i done the same thing and it ended up costing me 3x more money then if i would of if i built it right the first time.
I agree, forged pistons, and lower that compression ratio.
If you are doing a stroker the cheapest and easiest way to get the lower compression is to keep big combustion chambers in your heads. If you are ordering the AFR heads then make sure you get big combustion chambers with them.
If you lower your compression ratio from 10:1 to 9:1 you aren't going to loose much horsepower and you will be much better off for when you add a supercharger.
build it at 10 to 1..............keep the boost at about 4 psi and you'll be ok........the C5 guys are getting away with it.........BUT get it tuned for the added fuel needed
Forged pistons are some insurance, but with detonation they will fail also.
However, if you have a low milage, or recently rebuilt motor, you can take out the stock pistons, and install dished forged pistons (JE), and lower the compresson for a much lower cost than buying larger chamber heads. You can do both and lower an LT4 from 10.8 to 8.3. Reguardless of what you do, detonation is your enemy.
That cam will also have quite a bit of overlap for a blower. With positive manifold pressure, you don't want the intake and exhaust valves hanging open too long of you'll blow some unburned charge straight through. However, running a cam like that lowers your dynamic CR (and also lowers effective boost) which will allow you to run a higher static CR. It's not ideal, though, for making the best power.
Get forged pistons, good rods (cast crank is OK), lower the CR to ~9:1 or less, and I'd choose a cam with a duration <220 on a 114 or greater LSA for better efficiency.
The LSx guys can get away with running boost at higher compression because the engine management and combustion chamber design are so much better than the good 'ole L98.
