I have a 94 vert, and today my iggee seat covers came. I was able to put the top piece on easily for the seat back. I am having trouble getting the seat cushion cover on. I see a lot of folks in the forum have used these. any tips on install the seat cushion piece. I can not find any spots to hook the straps to in back and the sides. Looking for people who have installed these to give me some tips.. thanks
I just installed some Wet Okoles on mine and I gotta believe the process is the same:
You need to take out the bottom cushion; which is a piece of cake to do. There's a clip at the front/bottom part of the seat. Just push down on the cushion while also pushing it back towards the seatback. This will release the clip and the cushion pops right out. Install the cover on it and pop it back in using the same method - just (this time) push down on the cushion while moving it forward so that it will re-clip.
FWIW...Remove just the bottom cushion...no need to remove the seat tracks or the whole seat. The cushion takes a few seconds to remove and re-install. Once you have the cushion out, you'll have no problem getting the cover on nice and tight...then just pop it back in.
I found the clip and the bottom seat came out in 10 seconds, I was able to do each seat in about 10 minutes each, and it looks really good. that was the best tip I think I have gotten. I tried for over an hour to put the seat cushion on with the seat installed.
THANK YOU !!!
When I installed my seatcovers the seatback portions slid right on, then I came to the same crossroads as you..I was like wtf, how are these going to go on? Thankfully I had the FSM for my car, looked up seat cushion removal & BINGO!
