gear ratio?
Old Nov 12, 2007 | 07:54 PM
vetteski98's Avatar
vetteski98
Default gear ratio?
anybody know gear ratio for 89 6sp w/ perf. axle package.
Old Nov 12, 2007 | 08:03 PM
CFI-EFI's Avatar
CFI-EFI
How do you know it has the "perf. axle package"? Did you find the RPO, "G92"? If you did, there will be another "G" RPO number that will designate the gear ratio.
RACE ON!!!
Old Nov 12, 2007 | 08:17 PM
vetteski98's Avatar
vetteski98
thanks for quick response.might not have perf. axe code G92 found code G87? How else could i find out.
Old Nov 12, 2007 | 08:56 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
1989 had two 6 speed ratios 3.54 early and 3.33 late. Look under RPO code list for your ratio.
Old Nov 12, 2007 | 09:07 PM
vetteski98's Avatar
vetteski98
thanks for the help
Old Nov 12, 2007 | 09:08 PM
CFI-EFI's Avatar
CFI-EFI
OH! I was just going by what you said. G87 designates "8.5" ring gear", which all manual transmission cars after 1984 have. One more "G" code other than "G92" should do it. Otherwise you can jack up the rear end and turn both rear wheels 1 revolution while someone counts the drive shaft revolutions.
RACE ON!!!
To gear ratio?
