Budget blower build up started.
Old Oct 3, 2008 | 03:40 PM
  #61
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Originally Posted by Deakins
Well when the engine lets go during a race you very well may be buying things like cylinder heads, block, and a camshaft. If you don't mind spending that kind of money when it destroys itself why not spend it now? There's also a difference between slapping some little blower on a kids old Z28 he drives to work and putting one on a high mileage, already raced engine to go RACE... Working on race car engines for years has taught me the areas that you can skimp on and ones that you can't...I have to say you are doing this backwards. Just my .02
Hey Brian, since you're tearing this down to bare bones anyway why not send the engine out for a freshening-up?
Hell you're into this build quite a bit money wise.
Talk to Rick White over at Explicit Racing, I just had my engine sent out for a new set of lower compression pistons and they do amazing work......and they are very reasonable.
Old Oct 3, 2008 | 03:52 PM
  #62
Corvette Chris's Avatar
Corvette Chris
It seems rather risky to throw all those new parts, on an 140k shortblock. The tight tolerances just aren't there any more.
Old Oct 3, 2008 | 04:42 PM
  #63
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I may do it for another reason.
I'm a contractor, I don't want to get this thing halfway torn apart, only to get called out on a contract. If I leave it together, when I get the call I can drop off the car and my parts to SloRvette, and let him have at it. It's not like I'll be driving it while I'm away.
Right now I'm fighting an oil leak. I blew a seal up at NHMS, one of the three on the front cover. I'm betting on the mechanical drive for the WP which I left in when I put the Electric WP on. It's OK for the street, I just can't race it anymore till it's fixed. Since I need to tear it down anyways...
Old Oct 7, 2008 | 06:22 PM
  #64
BrianCunningham
Guys,
I just got off the phone with my builder.
I misunderstood him
He was talking about putting the blower on or heads & cam not both
I'd just like to publicly appologize to him for misunderstanding.
I'm just glad he's still interested in doing this project.
So, looks like I'll be doing a shortbock.
Old Oct 8, 2008 | 12:15 PM
  #65
Deakins's Avatar
Deakins
Eh that kind of stuff happens from time to time in my shop as well; keep us posted Brian!
Old Nov 22, 2008 | 02:02 PM
  #66
BrianCunningham
It turns out a stock LT1 intake will work with the new AFR's
So I'm just going to use the spare one I have
Originally Posted by rklessdriver
Brian,
Here is the pic from Nolands engine thread.
This is a Fel Pro stock replacement LT1 gasket (PN1284) up to his AFR 195 Comp Ports . I actually used this Fel Pro LT1 gasket (added just <.060 to the roof) to port match his LT4 intake and when we put it on the motor the port alignment was perfect.
We then put the GM "LT4 Off Road" gasket (777) up to them to show the difference.
Now in the end since Noland had an LT4 intake which has more sealing surface above the intake port I just used the GM LT4 777 gasket for assy. It expidited assy (no gasket trimming) and Noland didn't seem to keen on me taking a pocket knife to his brand new gaskets if I didn't have to...
Another option is SCE, which has a few different LTX gaskets (that have different port heights) and you could get one that didn't require any trimming on the 195's. I had to go with SCE intake gaskets on my 210's.
Reguardless LT1 intake and gaskets on the 195 Comp Ports is easily done.
Will
Old Nov 22, 2008 | 06:57 PM
  #67
cv67's Avatar
cv67
St. Jude Donor '05
Try matching a gasket up to your heads and intake to see the difference?
Old Nov 22, 2008 | 07:54 PM
  #68
mseven's Avatar
mseven
what did you end up buying for the lower end components ?
Old Nov 22, 2008 | 09:56 PM
  #69
BrianCunningham
Nothing as of yet.
My last client had a heart attack when I told him the cost of what he needed to do what he wanted.
I'll pickup a stock gasket next week and double check.
Old Mar 6, 2009 | 01:45 PM
  #70
BrianCunningham
Well I just made by shortblock builder happy.
I got the final specs for my engine, so I just gave him my credit card #
Going with a 9:1 compression, which may seem a little low, but my tuner thinks I may max out the S-trim, so that will leave me room to send it back and have it rebuilt as a T-trim.
Going with a 5.7 rod, and not a 6, for the dwell time at the top.
I am going with an internal balance on this, so a zero balance flywheel.
With that in mind I'm getting the McLeod street twin clutch with the detachable weights.
It will be a custom Nitrous/Blower cam 220/236 duration.
Here's the shop I'm using, thanks to Cuisinartvette for finding it.
http://qmpracing.com/
Old Mar 30, 2009 | 05:02 PM
  #71
BrianCunningham
I got some pics from my machinist of the block being worked on.
-----Original Message-----
To: swiftwood@aol.com
Sent: Mon, 30 Mar 2009 3:46 pm
Subject: Re: LT1 383 shortblock for a blower
Hey brian
i am working on a new program for the main caps on your block
instead of using a stepped cap like everyone else
i want to use a flat cap that way you would get a better register in the block
its taking a little longer than i expected but the result will be far greater
Brad
Old Mar 30, 2009 | 05:17 PM
  #72
rickneworleansla's Avatar
rickneworleansla
Whats the lift and LSA? Just curious. I recently installed a cam and I like to know what other people are using for different applications.
Old Mar 30, 2009 | 05:21 PM
  #73
BrianCunningham
He was talking around .550 lift around 114 on the lobes, but don't quote me on that
Old Mar 30, 2009 | 09:12 PM
  #74
96GS#007's Avatar
96GS#007
Another build!
Whose rods and crank did you choose?
Old Mar 31, 2009 | 09:21 AM
  #75
BrianCunningham
SCAT, and yes I've having him check the crank for the errors you found, thanks for the alert.
I guess the parts are forged overseas but they're machined in SoCal.
Old Mar 31, 2009 | 02:31 PM
  #76
96GS#007's Avatar
96GS#007
It's rather distressing...Both Eagle and SCAT are machined in the US and the issues with both have been machining issues.
Be sure to check your rod/block clearance, especially if you're going with I beams with bolts or regular H beams. I have the SCAT Q-lite H beams in my build and had no issues.
Old Apr 14, 2009 | 09:33 AM
  #77
BrianCunningham
More pics of my block being work on
To Budget blower build up started.
Old Apr 14, 2009 | 03:09 PM
  #78
BlackHarleyMan's Avatar
BlackHarleyMan
AWESOME!
Old Apr 20, 2009 | 08:08 PM
  #79
BrianCunningham
More info
Sent: Mon, 20 Apr 2009 6:38 pm
Subject: RE: They want to know how long to build a motor
Hey Brian
I decided to machine another 3/16 key in the crank 180 deg from the orig
This way you have 2 keys holding that hub
That will be much stonger that way especially in a boost situation
Brad
Old Apr 26, 2009 | 12:29 PM
  #80
BrianCunningham
Shortblock's done!
Sent: Sat, 25 Apr 2009 5:17 pm
Subject: Engine
Hey Brian
Thanks for your business!
This engine came out really good I think you will like it
I was explaining the whole main cap issue with you
When people normally convert a 2-bolt block to a 4-bolt they normally use a stepped cap to fit in the stock 2-bolt registers
The problem with that is you have to have a .002-.005 air gap under the ends where the extra bolts go through so you are definitely
Flexing the cap the way we do it is that we machine a whole new register in the block so you have the bottom of the main cap completely flat now you have full contact with the block not just the step.
This way is harder to do (if you do not have a cnc machine) that’s why most shops use the step cap they just bolt them on and drill it with a drill bushing and tap it. I am not knocking that way, hell I used to do the same thing. Now we have a better way of doing it so we pass that on to our customers. Our shop is outfitted with the latest in machinery. I pride myself in having the best equipment available. So we can build a better engine for you.
Thanks again
Brad
BTW normally you hit the water jackets when you do his he didn't
Drainbacks for the AFR's
EDIT:
BTW He couldn't make the S.C.A.T. crank balance with the 5.7 rods so he went ahead an upgraded me to a Lunati crank no charge.
You can see the heavy metal it took to balance it.
