1985 display (dash)
Old Nov 15, 2007 | 12:08 AM
ridgevette's Avatar
ridgevette
Cruising
Default 1985 display (dash)
My issue is as follows. For daytime driving the dash remains consistent for illumination. At night (headlights on) the dash starts to pulse. By this I mean get brighter then dims, and repeats. I keep the level low. Could this be the voltage regulator in the alternator?
Old Nov 15, 2007 | 01:06 AM
jhammons01's Avatar
jhammons01
Most likely grounding issues within the Dash circuit.
Old Nov 15, 2007 | 12:58 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Dash ground to frame or engine, clean and tighten, or dash sensor going bad or internal dash ground, search for archive posts... you'll find alot of info
Old Nov 15, 2007 | 06:29 PM
ridgevette's Avatar
ridgevette
Cruising
Thanks, any thoughts as to why it only happens with the headlights on
Old Nov 15, 2007 | 09:54 PM
jfb's Avatar
jfb
More likely you have the dimming circuit on one of the two circuit boards in the cluster that needs repair. The dimming circuit is fully active with the headlights on. You can clean the ground wire connection, but my money is on old age of some electrolytic capacitors on the circuit board.
Old Nov 15, 2007 | 11:03 PM
corvettedan22's Avatar
corvettedan22
My 85 does exactly the same thing...
Old Nov 15, 2007 | 11:10 PM
brian84's Avatar
brian84
my 84 has almost same problem. with head lights on the dash goes from being normal ilumination, to real bright some times. not often, but it does do it from time to time.
Old Nov 16, 2007 | 12:26 PM
jhammons01's Avatar
jhammons01
I guess some one needs to post links or Pictures of the actual grounding spots in this thread.
I don't have any. Do you Vinnie?
Old Nov 16, 2007 | 02:01 PM
redrose's Avatar
redrose
dash and headlights did this on my daughters car, not so much change as to be obvious, just enough to say ''something is NOT right''...alternator was bad.
Old Nov 16, 2007 | 02:43 PM
corvettedan22
I belive it was the ground to the dash or the connection to the dash... But i never to to check it out.
Old Nov 16, 2007 | 04:43 PM
Former Ford Boy's Avatar
Former Ford Boy
Sometimes the ground problem is inside the gauge cluster. This was the case on my 87. There are two large circuit boards inside the cluster with a large connector between them. The ground pin inside that connector sometimes loses good contact and must be cleaned and in some cases modified to permanently resolve the problem. Here is a link to a tech article showing how to disassemble and repair the cluster. The article is from Corvette Magazine
http://www.corvettemagazine.com/1999...ash/dashp1.asp
Hope this helps!
Phillip
Old Nov 16, 2007 | 09:09 PM
ridgevette's Avatar
ridgevette
Cruising
Well, I am glad to hear there others out there with this issue, not in a malicious way of course but just to know that my car does not have something really really weird going on (gremlins!). That is a good thing with forums...company!. The ground idea is intriguing, but to my way of thinking the unit seems to operate OK with the headlights off and then does this brighter/dimmer thing with the headlights on. If the ground were bad I would expect low brightness, intermittemt operation or no operation. I am leaning toward an over-voltage in the system, which would point to the regulator in the altenator I think. When the headlight s go on doesn't the alternator kick out more juice? If the regulator can't take the extra juice, it may be passing the voltage through as opposed to clamping it like it is supposed to. What do you guys think?
Old Nov 16, 2007 | 10:34 PM
jfb's Avatar
jfb
The alternator supplies the car's electrical current when the engine is running, so yes, turn on the lights and the alternator output CURRENT increases. The voltage regulator attempts to maintain constant output voltage, so if you turn on the headlights, the alternator voltage remains the same value, about 14.7 volts cold, 13.7 volts hot. Sometimes the voltage regulator will oscillate at a low frequency and you will see all the lights flicker. It can also happen that the voltage regulator won't oscillate until the output current gets to some value, like when you turn on the headlights. You can prove its an oscillating voltage regulator by unplugging the alternator and see if the flickering stops. Personally, I use an oscilloscope to look at the alternator output waveform.
Old Nov 16, 2007 | 10:57 PM
ridgevette's Avatar
ridgevette
Cruising
Thanks for the tip, I am going to try this on the weekend.
Old Nov 20, 2007 | 12:48 PM
Toypar's Avatar
Toypar
The battery buffers the alternator signal.. Try replacing the dimmer switch ...
Old Nov 20, 2007 | 05:20 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default flicker
try turning off the fog lights to reduce the alternator load if the air conditioner or the rear window heater is on at night.
These high draw systems really put the alternator to the test.
Lessen the load, and the rest of the car works better.
Old Nov 20, 2007 | 10:56 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Tape something opaque over the light sensor on the top left corner then take it for a spin and see what it does.
To 1985 display (dash)
