battery drain saga continues
Old Nov 19, 2007 | 05:42 PM
stick105's Avatar
stick105
Default Dash corrected thanks guys!!!
Ok I think I got it solved! Thanks to all that helped me. This is what I did. I disconnected the positive cable from the battery terminal and jumped a VOM set on 20m DCA with my red lead plugged into the A plug and the black lead set into the COM plug on my meter. I read a .o3amp until the curtisy lights timed out and went off and then the meter read .01amp. The digital dash is the only electrical component missing. I think these readings are below the 50 mill. amps required. CFI and JFB your input would be well appriciated. And thanks for all you advice guys.
