Rear Wheel Bearings
Old Nov 16, 2007 | 03:28 PM
derv3tt3's Avatar
derv3tt3
Default Rear Wheel Bearings
Well I guess its that time to change the bearings,how hard is it?
Old Nov 16, 2007 | 03:41 PM
Aardwolf's Avatar
Aardwolf
I thought it was easy, I had no troubles with it.
Old Nov 16, 2007 | 03:50 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
If all goes will its not bad. I was doing the bearings, U-joints and shocks at the same time so the rear was mostly removed making it a lot easier.
Old Nov 16, 2007 | 04:12 PM
derv3tt3's Avatar
derv3tt3
Any special tools needed?
Old Nov 16, 2007 | 04:17 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
There's a good sized torx socket that you need to remove the bolts that come from the inside. I can't remember what # it is. Otherwise its pretty straight forward. Two recomendations, replace the shim that goes behind the bearing and use a quality bearing like AC Delco.
Have Fun, Paul
Old Nov 16, 2007 | 04:27 PM
derv3tt3's Avatar
derv3tt3
Many thanks.
Old Nov 16, 2007 | 05:01 PM
Mark85Vett's Avatar
Mark85Vett
Its been a few years, but I think its a T-55 torx. You'll also need a 36mm socket for the axle nut.
Old Nov 16, 2007 | 05:06 PM
genefree3's Avatar
genefree3
and spend the money and get a QUALITY T#55 bit, not one from Ace Hardware.
Old Nov 16, 2007 | 05:10 PM
Carl Johansson's Avatar
Carl Johansson
a couple of extension wobblers make it a whole lot easier to get that 55 onto the torx head!
Carl Johansson
Old Nov 16, 2007 | 06:10 PM
any4xx's Avatar
any4xx
Let me "Ditto" on the U-joints. As long as you're back there, it's easier to get the three T55 bolts out with the half-shafts out. And if you have enough mileage on your car to be replacing the hubs, the U-joints are surely not far behind. But to answer your question, it's not very difficult at all. Just replace the teflon-coated washers that go between the spindles and hubs or you might have noise later. I paid $7.21 each for the washers at the Chev. parts counter.
Old Nov 16, 2007 | 06:19 PM
Muffin's Avatar
Muffin
The spindle nuts,36mm, can be a problem. Torqued to some ungodly number. Be sure you have a plan to get back to the correct torque.
Old Nov 16, 2007 | 06:24 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
If you are replacing hubs, you need to do u-joints. And also take a heavy look at the condition of your bushings.
To Rear Wheel Bearings
