From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Originally Posted by mseven
how tall, and wiper motor and ac bracket will be the problem
Not sure. IN looking around the net all they list is "tall". Is there a standard for "tall"? My initial fit I'm having a little trouble getting the originals on. Again, quick rough fit. So I'm thinking I may need "tall".
This is the same on every site I look at. Right now I'm having a little trouble getting the rockers under the stock covers. However, I don't think it will be a problem.
I had the originals powder coated, but as things start to come together I kinda like these, if I can get away with standard height:
ones usually listed as "tall" are noticeably bigger and I have seen a couple w/bigger dimensions for big gear. Ones like 1297978/979 (what I have and clears 1.6 pro mags )are about 1/4''-1/2'' taller than stock. Ones shown as tall are usually also perimeter bolt style. see linky: http://www.superchevyperformance.com/category_s/110.htm
ones usually listed as "tall" are noticeably bigger and I have seen a couple w/bigger dimensions for big gear. Ones like 1297979 (what I have and clears 1.6 pro mags )are about 1/4''-1/2'' taller than stock. Ones shown as tall are usually also perimeter bolt style. see linky: http://www.superchevyperformance.com/category_s/110.htm
Hmm..I like the look of the center bolt, since that's how it came from the factory.
The front of the cover goes all the way down, the rear is still up. I suspect once I adjust the nuts I should clear it. I am dry fitting with no gasket, so that will help some too.
I would like something "corvette" looking rather than "chevy".
I have 1.6 Pro Mags too. Did you get new covers because they didn't fit under the stock ones?
