5.3L gets over 400 hp
One of these days I'll have to get into these LS engines. I just haven't developed much interest in them yet.
Have fun!
To get that kind of HP out of an N/A 5.3 you would need a big cam and some pretty serious head work. I have a 5.3 in an '05GMC truck that makes 420 hp and 450 tq, but it has a blower on top with 9psi of boost. Also bigger cam, headers, and boost cooler.
The 5.3 is basically an iron blocked LS1 with smaller bore, heads that don't breathe too well, and a smaller cam. Made more for low rpm power than performance apps.
I just assumed he was taking about the 5.3 truck engine.
A 5.3 can be an excellent choice for an engine. Is the 6.0 better, sure, but it depends on your goals and budget. I wouldn't dismiss a 5.3 though.
The 5.3 has plenty of displacement for that kind of horsepower. I am sure as time goes by there will be more and more aftermarket parts for them also.
is that it wouldn't be likely to migrate an LS4 into a RWD application
simply or cheaply.
The RWD versions of the 5.3L are the LM4 (Al block/Al heads), LM7
(Fe/Al) and the L33 (Al/Al). At least this was the case as of 2007/03
when I gathered some information on the subject - see post #55 in
Corvette Fever- Project C4orce- Have you heard?
I still haven't heard of anyone taking up my suggestion of playing
'mix-'n-match' with bores and strokes. With a 3.27" stroke and a
6.278" rod, interesting things become possible. In a V8 block with
a 4" bore, a 3.27" stroke gives a displacement of 5.4L (329 ci). Such
a combination would produce redlines of the following values
- 6,500 RPM (With an OEM-like conservative piston speed of 3,550 FPM)
- 7,350 RPM (Equivalent to the PS of 4,000 FPM that many tuner
products enable. - 8,500 RPM (Equivalent to the PS of 4,600 FPM that the LS7 has)
By the way, has anyone discovered a steady source of sub-$1K 5.3L
engines? RAM AIR FORMULA kept talking about these in the Project
C4orce thread - that was half a year ago and I still see 5.3L's selling
closer to $2K.
mileage that they could be used without needing significant freshening.
How about a cap of 20,000 miles? Personally, I'd prefer much less
mileage but I'll give you a fighting chance to keep your money.
Plus, the price has to be for a complete package: full accessories,
engine harness and ECM/PCM, intake, ignition, the works. (Bonus
points for engine/transmission packages.) The purpose is to scavenge
as much as possible up front - going into a swap we have nothing and
need everything.
runs mid 12's at 112 or so off the bottle. was almost in the 11's with what was thought to be a 150 shot. car suffers from slipping clutch and bald nitto drag radials.
nonetheless its a very powerful little motor. makes the ford 4.6 modular look like crap in comparison n/a to n/a.
I dont have a link.....I would bet most junkyards or places like truck forums on LS1.com have some fair deals on something like that. You are right in one respect though, you need a lower mile example as you just cant bore them repeatedly such as a typical sbc.Good part is those motors are very durable and last a long time.
While certain engine codes have higher outputs when installed in some
models of truck chassis, the lower base output appears here.
4.8L (96.01 mm x 83 mm)
- 293ci (3.779" x 3.27" w/ 6.278" rod)
- 325ci (3.779" x 3.622" w/ 6.098" rod)
LMF Fe/Al 301HP/325TQ @ 5200/4500
LC9 Al/Al 310HP/335TQ @ 5200/4400 (FlexFuel)
LH6 Al/Al 315HP/338TQ @ 5200/4400
LY5 Fe/Al 320HP/340TQ @ 5200/4200
LMG Fe/Al 320HP/340TQ @ 5200/4200 (FlexFuel)
nitrous.
Runs mid 12's at 112 or so off the bottle. Was almost in the 11's with
what was thought to be a 150 shot. Car suffers from slipping clutch
Nonetheless, it's a very powerful little motor. Makes the Ford 4.6 modular
look bad in comparison - n/a to n/a.
manual? Any guess as to the run weight?
its a 94 camaro originally a 6 cyliinder car..now sports a 6 speed, hence the slipping clutch mentioned
and 4.8 liter. 00 camaro Ls1 intake on it as well as the wiring harness. 4.56 gears12.33 at 113 on motor and ran 12.0 on the spray missing 4th. next run broke the 10 bolt rear.
i'd say the car weighs 3500-3550 lbs with him in it, or so. its hard to tell but the car makes GREAT power. probly 375whp. not bad for 283 inches
best thing is you can pick up 4.8's and 5.3's for a dime a dozen. it used to be 6 liters but they now became popular and prices gone up. now its 5.3's and 4.8s. there are capable plants
This vendor is rated at 99.3% on 5228 transactions. Past examples
show that their OBO items close for within $200-300 of the asking.
5 Original Miles - $3,500 OBO
2004 5.3L L59 (295HP/330TQ @ 5200/4000) w/o trans, incl PCM, harness & all accy
3,200 Original Miles - $2,000 OBO
5 Original Miles - $1,900 and counting
these are high mile (70K+) and lack key swap items that the examples
above include.
