Setting the Distributor
Old Nov 18, 2007 | 04:43 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Setting the Distributor
Here's what I was going to do...
Since I have the intake off, and the timing cover off, I was going to install the intake, line up the timing marks on the sprockets, and set the distributor to cyl 1 at that point.
Anyone have a problem with that? That should work, right?
Thanks.
Old Nov 18, 2007 | 05:44 PM
rssshen vette's Avatar
rssshen vette
Thanks.
That should work, but before you do so make sure the #1 piston is TDC.
Old Nov 18, 2007 | 05:53 PM
jsup's Avatar
jsup
Matching up the timing marks takes care of that, no?
Old Nov 18, 2007 | 06:21 PM
JackDidley's Avatar
JackDidley
If they are at 6 oclock and 12 it will be on number 6 compression stroke. If they are both at 12 it will be on number 1.
Old Nov 18, 2007 | 06:26 PM
jsup's Avatar
jsup
Cool. I just learned that doing some research.
Question. With the heads off, and the timing marks aligned, the #1 cyl is at TDC. I guess that is power stroke, not compression?
Old Nov 18, 2007 | 07:13 PM
c4cruiser's Avatar
c4cruiser
With the heads off, you will have to look at the position of the lifters for cylinder #1. With the timing mark at 0 and the piston at TDC, the cam lobes for #1 will have to be down (both lifters should be at the same height and low in their bores).
If you turn the crank 1 full turn again, the piston will be back at TDC again but the exhaust valve will be open. If the lifters are at different heights, you are 180 degrees out.
Old Nov 18, 2007 | 07:34 PM
genefree3's Avatar
genefree3
This procedure is also covered in the FSM with pictures!
Old Nov 18, 2007 | 07:37 PM
jsup's Avatar
jsup
Thanks, on to the cam.....
I believe it is impossible to install the cam 180* out as long as the timing marks are lined up.
You can set the cam gear to either 12:00 or 6:00. 6:00 is a bit easier since the points are closer and easier to line up.
My reasoning is that the crank is doing a 720 degree cycle, while the cam is doing a 360* cycle. Therefore, the pistons are all in the same exact position twice during the cam cycle. Therefore, impossible to be 180* out. The CAM sets what the stroke turns out to be, not the crank.
Think of it this way, if the marks are at 12:00 crank and 6:00 cam, and the crank cycle is twice the cam cycle, I can move the cam gear to 12:00 (180*) and the crank will be exactly where it was when the cam was at 6:00. Why? Moving 1/2 a cycle moves the crank 360* so the pistons were in the same exactly spot, although the cam only moved 180*.
Make sense? Or am I full of shet?
Old Nov 18, 2007 | 07:39 PM
jsup's Avatar
jsup
I have an FSM and I'll get to it tomorrow. Doesn't hurt to ask, right?
Old Nov 18, 2007 | 07:49 PM
JackDidley's Avatar
JackDidley
Not sure about that last part but you are correct. If the marks line up the cam cant be out 180.
Old Nov 18, 2007 | 09:25 PM
Sam Lam's Avatar
Sam Lam
If you have the valve cover off the heads, you can observe the valves on #1 and #6 cylinders as the timing mark approaches TDC. If you are approaching TDC for #1 cylinder, the valves on #1 will not move AND the valves will "rock" on #6 cylinder. If the valves are opposite what is stated, you are approaching TDC on #6 cylinder. FYI
Old Nov 18, 2007 | 10:01 PM
CFI-EFI's Avatar
CFI-EFI
Whether the heads are on or off won't affect what position the engine is in.
What is the difference between TDC at the compression stroke and TDC at the power stroke?
RACE ON!!!
To Setting the Distributor
