i picked up my new (new for me) 96 lt4 this past weekend from md. drove home 370 miles. quite the car, the prior owner had installed zz9 cam, 4:10's, all of the R& D braces made fot he car, and a list of other things.
when i got home i did the typical check- oil etc...what i did find that concerns me is the large pully front top center of the engine (i think it is the water pump pully) has a wobble to it. the belt does not shift it tracks perfectly dead center from idle to 6k rpm. the pulley itself deflects 3-4 mm every turn. all of the other pulleys are tracking perfect. question..is this common? if left alone will it cause problems? how difficult is it to fix?
thanks..
btw a new amg c55 was playing with me through ny...he was 3 cars ahead of me doing around 70 and smashed the gas (amg benz's do sound nice) by 130 i had pulled by him and put 2 lengths on him. when we slowed i get the thumbs up from the driver of the amg..
Are the pulley bolts loose or missing? If not and you can move the whole water pump snout, the pump needs to be replaced ASAP. Mine wore out that way and made a scraping sound, there was a lot of play in the pump shaft.
Can you post a pic of your pulley including the front of the motor? There shouldn't be a pulley at the top center of the motor.
Here's a generic pic of the 96 motor:
Note that the alternator has a pulley assembly that includes a cooling fan that's about 5" in diameter. The A/C compressor is below and to the left.
got a camera? can you take a picture for us? I've actually had a bent ps pulley before. When I got the car it came without a pump but did have a pulley so I put the pulley on a new pump and noticed it had a 1/4th inch wobble when running, turned out someone bent the pulley..
In this cutaway view of a 92 LT1:
there is a black pulley almost directly under the alternator ^. That is the power steering pump pulley. Is that the one?
The LT1 and LT4 motors have the accessories in pretty much the same place so your's should be no different.
IIRC, the pulley is a press-on fit to the pump shaft. You most likely have a bent shaft in the pump or a bad internal bearing or bushing.
Does the pump make any noise or do you feel any sort of pulsation when turning the steering wheel?? If you remove the serp belt, try to move the pulley around. It's even possible that the bolts that hold the pump to the accessory bracket are loose.
I'd check the pully first before I bought a new pump. The pully has to be removed from your old one, and re-installed on the new, when you replace the PS pump. They'll bend rather easily, as I once found out.
Yeah those pulleys don't stand up to much force before they get a wobble.
Replacement is a very simple job:
-leverage the tensioner and remove the loosened belt
-use a puller tool on the old pulley
-use a pusher tool to get the new one on
-leverage the tensioner and put the belt back on
No other parts need be moved out of the way. A standard angled serpentine tool plus a very short 1/2 drive socket will clear the accordion to leverage the tensioner.
The GM PS pulley puller/pusher set is a cheap little thing at autozone. They are a bitch to use though; they require a LOT of force to turn.
