Miss Fire Problem
Old Nov 21, 2007 | 12:19 PM
wrnglrwrercpe's Avatar
wrnglrwrercpe
7th Gear
Default Miss Fire Problem
I'm a newbie, tried searching, but didn't see what I was looking for. I have an 89 C4 with a stock L98. I have a nice valve cover leak and decided to change out the plugs, wires, rotor, cap, and coil while I was at it. Everything was running as it should be prior to the changes. Now I have a slight miss while in idle, and it is really missing when I'm driving, especially if I attempt to keep a constant speed. I've since re-checked and replaced everything, and still have the problem. While re replacing the spark plugs, I noticed that #2 and 4 didn't appear to be firing nearly as well as the rest.
Any ideas?
Old Nov 21, 2007 | 04:50 PM
gw962's Avatar
gw962
You might ohm your injectors. My '90 developed a miss last week and when I checked, the # 6 injector only ohm'ed at 5.8. All others were 16.7 +/- .2.
Old Nov 21, 2007 | 06:31 PM
Muffin's Avatar
Muffin
Obvious question is did you have the miss before you changed parts? If no then you likely didn't do something right. My first guess would be two plug wires swapped. Don't laugh, some of the very best have done it. While you are checking make sure the plug wires are fully seated, both in the cap and on the plug. I would also ohm the injectors as gw962 suggested.
Old Nov 21, 2007 | 06:37 PM
geogolf's Avatar
geogolf
Default missfire
tell me about it. that is what i did firing order 18436572 i had it 18346572, car was backfiring thru exhaust changed to correct order bingo sounds healthy again so make sure wires are on correctly
Old Nov 21, 2007 | 06:42 PM
CFI-EFI's Avatar
CFI-EFI
You frugged something up during your work. I'll bet big bucks you have a couple of plug wires switched with one another (#2 & #4?). It can be tough to follow the wires around the back of the valve covers and making sure you haven't jumped from one wire to another.
RACE ON!!!
Old Nov 21, 2007 | 07:19 PM
johnnyzvette's Avatar
johnnyzvette
I made that mistake a few months ago...drove me nuts trying to find the problem, turned out to be the obvious....wires swapped!
Old Nov 21, 2007 | 10:41 PM
wrnglrwrercpe
7th Gear
lol.. yeah, I've checked the plug wires, and made sure they're seated good. Didn't have this problem prior to the changes, which is why it's frustrating. I've got no problems accelerating, but trying to maintain a constant speed it runs rough.
Old Nov 23, 2007 | 05:15 PM
wrnglrwrercpe
7th Gear
After re-checking the plug wires, checking the fuel injectors, I decided to put back in the stock coil ( I had replaced the stock coil with an MSD 50K Volt coil), and that solved the problem!
To Miss Fire Problem
