timing mark
Old Nov 23, 2007 | 09:12 AM
geogolf's Avatar
geogolf
Default timing mark
did the lt1 intake swap and need to check timing, but i cant seem to see the mark on crank. is it on the crank pulley or on the balancer/damper thanks geo pic would be great if someone has one
Old Nov 23, 2007 | 08:47 PM
makn u shiver's Avatar
makn u shiver
its on the balancer you should be able to see it easy
Old Nov 23, 2007 | 09:07 PM
geogolf's Avatar
geogolf
Default mark
shiver that is what i thought also, but i cant see it at all. that is why i wanted a pic, it is just a groove cut in the balancer right
Old Nov 23, 2007 | 09:22 PM
makn u shiver
hi,ya its just a groove cut in .unless the balancer is really greasy you should be able to see it.just get some one to sit in the car and bump the engine over until you can see the mark up top.the mark you should see easy its a deep groove .
To timing mark
