lowering the front.... help please
what would be a way to lower the front to the max before going to a coilover kit. i was thinking of taking all the rubber on the spring, the metal shims, and the flat aluminum braket. pretty much having the spring rest on the crossmember.
could this be done?
would this drop the car lower than 1inch?
i was told the spring rate changes, how so?
now the car is pretty much a full drag car with very little street use, i know by the spring resting on the crossmember it causes more stress but you think it would be fine since it does not see much street use ? thanks
