Pilot bearing is a bushing!
Old Nov 28, 2007 | 06:55 PM
Nav Vet's Avatar
Nav Vet
Default Pilot bearing is a bushing!
1991 L98, 6spd.
I just removed the pilot bearing, and I see that it is not a bearing at all.
It is gold in color, and appears to be brass. I'm wondering if I should have not taken it out. The replacement is an actual bearing.
Thoughts??
Old Nov 28, 2007 | 07:05 PM
cv67's Avatar
cv67
St. Jude Donor '05
Just use a brass bushing, an oil impregnated one if you can. Dont care for the bearing type.
Old Nov 28, 2007 | 07:55 PM
redrose's Avatar
redrose
it's 'sintered bronze, oil impregnated',trademark name ''oil-lite'', been used for many decades, good for 100k+ miles...seen several 'roller bearing' types come out in small chunks.
Old Nov 28, 2007 | 08:31 PM
Nav Vet's Avatar
Nav Vet
thanks for the good info!
Old Nov 28, 2007 | 09:55 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Yeah, I prefer the bushings over the bearings as well. Once you try to remove a bearing, you will too. PITA!
Old Nov 28, 2007 | 11:51 PM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
Plus a bronze bushing can't lock-up on you like the bearing can.
Old Nov 29, 2007 | 12:44 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Supposedly GM switched to the bearing sometime around 1989 in the vette, then switched back to the bushing in 94. Is your clutch original?
Old Nov 29, 2007 | 01:23 AM
cv67's Avatar
cv67
St. Jude Donor '05
Didnt know they used the roller bearing in the Vettes, thoguht it was just in the 80s diesel pickups. Hmm.
Old Nov 29, 2007 | 03:34 AM
mechguy79's Avatar
mechguy79
Wow, I was just about the screw this up royally then. Glad I read this post.
To Pilot bearing is a bushing!
