89 that scans as 86?
Old Dec 1, 2007 | 10:50 PM
joeld's Avatar
joeld
Default 89 that scans as 86?
Hey guys, I will try to keep this short. I have a 1989 L98 Auto., car runs just fine after several years of working and replacing many parts. This is more of just still trying to learn about ECM's than a repair. I have a Actron scanner with the GM cartridge that works just fine for my cars. On this tool the year,model, and engine specifics have to be entered. If I enter 1989 (which it is), I get a error reading. I have to enter it as a 1986 in order for tool to read any codes or data. Tool does work as it shoul as I have owned it for 10 years and use on several other cars with OBD1. So,,,,? could it have the wrong PROM and/or the "service replacement" ECM? I know that when a ECM is replaced the PROM is usually kept from the old ECM and installed into new one. Correct? Any words of wisdom I would greatly appreciate. Thank you.
Joel
Old Dec 2, 2007 | 07:14 AM
rodj's Avatar
rodj
Pull the chip (memcal ) out of the ECM and confirm that it is a '89 code.Should be ARAP or similar.
The ECM's are the same from 86 -89 so the chips interchange and run if not correctly
Old Dec 2, 2007 | 09:15 AM
Matt Cramer's Avatar
Matt Cramer
Joel
Whether the person doing the replacement pulls the EPROM is going to depend on who was responsible. There's probably a lot of backyard mechanics (and quite likely some professionals too) who, if they conclude the ECM is bad, would just go to a junkyard, get another one, and just plug it in without opening the box. I think someone's done that to your car.
Old Dec 2, 2007 | 09:20 AM
tequilaboy's Avatar
tequilaboy
In addition to checking the label on the eprom, your scan tool should be able to read and display the prom id.
That should tell you which bin file is programmed if it can be identified (and hasn't been modified by somebody).
Read the prom id and post it here. Maybe someone can id it for you.
Old Dec 2, 2007 | 10:31 AM
joeld's Avatar
joeld
Yes, scanner reads Prom ID# 1011. And thanks for all replies.
Joel
Old Dec 3, 2007 | 09:28 AM
convas's Avatar
convas
I checked for that prom ID# on http://www.chevythunder.com/ and did not see it listed.
Old Dec 3, 2007 | 11:02 AM
joeld's Avatar
joeld
Thanks for all the replies. Should I even be concerned about this issue? Car runs and drives very well. Looks to me like the 86 and 89 all have same MAF, MAT, etc. Not sure of any difference in fuel pump pressure or spark timing. Only problem I have as we speak is the MAT reading is a constant 392 degres. But it has been like this for a long time, just keep forgetting to repair. Doing that now.
Joel
Old Jan 7, 2008 | 11:25 AM
joeld's Avatar
joeld
I finally got some to remove the ECM and check the numbers. On the ECM it has a label: Reman. by GM corp Service Part #16198445. On the Prom it has #APKC 1304. Does this look correct. Thanks
Joel
Old Jan 7, 2008 | 12:52 PM
89onlyZ51's Avatar
89onlyZ51
That is one of the correct proms for an '89 auto - I think it's one of the earlier versions and is not as common as the others.
Old Jan 7, 2008 | 01:11 PM
joeld's Avatar
joeld
Thanks for the reply! Now, do you have any thoughts on why the car reads as a 1986 instead of 1989 when I use my scan tool?
Joel
To 89 that scans as 86?
