running rough when warm?90 l98?
Old Dec 1, 2007 | 11:04 PM
vetteman222's Avatar
vetteman222
Default running rough when warm?90 l98?
Any ideas on what would cause a l98 to run rough when warm?
Old Dec 1, 2007 | 11:43 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
injectors. Check them with an OHM meter, should be about 16 ohms.
Old Dec 1, 2007 | 11:58 PM
Sam Lam's Avatar
Sam Lam
as cold spec is 16.5 +/-.3 ohm. Hot reading will be higher.....if the injectors are good. Otherwise, you have a problem with the injectors.
Old Dec 2, 2007 | 04:58 PM
vetteman222
Default injectors
any kind of an estimate, on what that would take to fix?Obviously its dependent on how many injectors but any ballpark on what I would expect to pay?
Old Dec 2, 2007 | 06:22 PM
Sam Lam's Avatar
Sam Lam
A set of injectors will run you from about $200 (re-manuf) to about $300+ for a new set. You can change them out yourself (depending upon you having some basic tools and mechanical knowledge) and save the labor cost. You will need some plenum gaskets and new "O" rings for the fuel tubes and injectors. The gaskets and O rings will be somewhere in the $30 to $40 range.
If these prices seem steep to you, get a quote from a dealer or service center
This is not a difficult task and let me know if you need more info on this project
HOWEVER, make sure you have bad injectors before you start taking 'em out!
Bob
Old Dec 3, 2007 | 08:10 AM
KeyWestJack's Avatar
KeyWestJack
Before you spend any money do a simple check of some engine components like vacccum lines, spark plug wires, etc.
BTW, when you remove your plenum, you may want to replace your egr valve (suggest delco only).
To running rough when warm?90 l98?
