Distributor Shaft End Play
Old Dec 2, 2007 | 10:59 AM
geezel's Avatar
geezel
Default Distributor Shaft End Play
What is the acceptable end play on an L98 distributor shaft?
Old Dec 2, 2007 | 01:41 PM
CFI-EFI's Avatar
CFI-EFI
I have never seen a spec. Based on the new, used, and rebuilt, distributors I've seen anything under a 1/8" is OK. End play of .050" -.060" is common. I set mine between .006" and .010".
RACE ON!!!
Old Dec 2, 2007 | 01:55 PM
geezel's Avatar
geezel
OK. Thanks
Old Dec 2, 2007 | 09:38 PM
SJW's Avatar
SJW
Set it to no more than .010 to keep spark scatter to a minimum. I always shoot for .005. You can get the shims you need at a local speed shop, or from Summit, Jegs, etc. Moroso makes 'em, and others may, too.
Live well,
SJW
Old Dec 2, 2007 | 10:14 PM
redrose's Avatar
redrose
Default no mistake
distrib ''end play'' is intended to ''pump'' lubricant into the lower bearing as the shaft rises momentarily at rapid engine decel....shimming to reduce end play will result in premature lower distrib bearing failure
Old Dec 4, 2007 | 12:14 AM
SJW's Avatar
SJW
The only factory-published specs I've ever seen for distributor shaft end-play are from the 1966 and 1967 Factory Service Manuals. That spec states that end-play should be .002 to .007 inch.
I have never seen a published spec for end-play for an HEI distributor, but I doubt it'd be any different.
I've always aimed for .005 end-play.
Live well,
SJW
To Distributor Shaft End Play
