For those with TPI engines that have taken their intake apart, i'm sure you can all agree with me that its too complicated and frustrating. Its like they designed it so that you drop a bolt (and you will) it goes into a little nook and takes forever to get it out. If you disagree and think there are more complicated intakes out there, I would like to see a description and some pictures
I have not dropped a bolt in mine, but years ago I installed TPIS Large tube runners, Big Mouth manifold and ported the plenum. I thought that part was pretty normal R&R.
There has been untold complaining about installing the SR on these pages. I did not even try it...forewarned was forearmend! My mechanic made a special tool to get at some of the bolts. Works fine, but it will test normal beings.
TPIs are a paint to mess with, and everything has to be reassembled in order so it all fits right. For the lower torx bolts try using a long 1/4" drive extension with a 1/4" to 3/8 in adapter, your torx socket on the eind of that. To get them started OSH sells a craftsman 1/4" flexible extension (looks like a cable), that makes it a little easier. Put some antisieze on the end of the threads, it helps. One in the DS rear is no fun as the windshield washer motor, booster line and everything else is in the way.
A telescoping magnet is a must on these cars.
I've had two TPI setups, an '85 Trans Am, and an '85 Vette. I had them apart so many times, I didn't think much of it. I was kind of intimidated the first time, but it's just parts. You unbolt stuff, and there it is. Just keep track of which bolts go where. Not too tough.
The first time I took apart a TPI I was 16. I never really found it that difficult. I will say that after installing the SLP runners its much easier with the allan head runner bolts and that nifty ball end alan wrench from SLP. If I ever have to pull another stock one apart, Im definately ditching the torx bolts!
It really is just a matter of doing some mods, make a few tools, throw a few tricks at it, and the frustration is minimized.
personally I love reading about how bad the super ram is. I dont have any issues with it. the first time was the worst... I did a few posted tricks on it and found better ways for me.
the only stock bolts on it are the runners to base. I replaced all of the rest.
Although there are some guys who throw tools and say F-it because they have the wrong screwdriver... those types I dont think can be helped.
Well I always have problems putting it back together. I've spent 4 hours on it today (longest its ever taken me btw) and dropped 2 bolts. At least one of my bolts never wants to thread right no matter how I put it in there. They should have kept it a once piece intake manifold. Yeah its still not all back together yet, its ridiculous. Doesnt help thats its 27* out there without the wind.
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
That is my dads type... I have never understood that. Doing stuff like that is just going to get you more worked up and you are going to end up breaking something. It isn't that hard to just get a new driver.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Better yet replace the torx bolts with allen bolts and get a long shank ball-end allen driver. It'll come off in 1/2 the time. Most of the frustration comes from not being able to get to the runner bolts.
Indeed. I went with polished button head allen bolts.
