Problems converting a stock carb setup to a TPI???
Im looking at getting a 350 block out of a 73 Camaro. What problems, if any, will I run into with making the switch from Carb to TPI? Im completely rebuilding the engine. Thanks, Zak.
You wont have problems with the engine itself fitting, however, make sure you get a low rise intake roughly 4.5 inches tall and a drop base air filter or it wont clear the hood. The biggest challenge I think is configuring the fuel lines and throttle linkage.
The car is already a TPI, right? A C4 probably? You want to take a carbed 350 core and rebuild it and install the TPI from the car on the engine and into the car, is that correct? If so Pete K. is absolutely right. Once the intake manifolds are off the two engines, the only differences are year related. There are no carb vs EFI issues. Also, there are no year differences that can't be dealt with. Things to be be aware of are the side the dipstick is on and whether there is a difference in the style of the rear main seal.
I not sure what year it started, but at some point in L98 production the flywheels had a weight cast into them. If you use one of these with an earlier engine it will cause a vibration. You will need a flywheel that's compatable with the older engine.
Paul
Your caution is a repeat of one already given. "Things to be be aware of are the side the dipstick is on and whether there is a difference in the style of the rear main seal." The external balancing in the rear came about in 1986 when Chevy went to the one piece rear main seal. Prior to that all SBCs except the 400, were internally, neutrally, balanced. The flange on the crank shaft had to be changed to accommodate the new seal. The crank flange bolt pattern changed at the same time, so this isn't a "GOTCHA" that will sneak up an bite you with no warning. A one piece seal flywheel or flex plate won't bolt up to a two piece crank shaft and vice versa.
What about putting the stock TPI on a 400? Will it support it? What problems will I have? Thanks, Zak.
The power band will be shifted even lower than it is on a 350. I personally wouldn't do it, as the power would probably drop off above 4K (if not lower).
Yeah, I figured it wasnt a good idea. So what do I put on a 400 for it to work with my car and be able to pass inspection? I heard a carb setup wont pass inspection...What do I put on it? Thanks, Zak.
It would bolt on to the 400 with the same ease as the carbed 350. Don't under estimate the possibilities. A TPI 400 won't be a high rpm screamer, but I know of Crossfire 400s that run quite well. If a Crossfire, why not a TPI? Especially as a DD, the TPI 400 should have more grunt and low rpm torque than the 350 it replaced.
If you need more power and rpm capability for either the 350 or the 400, there are all the usual "rams"; the mini, super, stealth, etc. In addition, Edelbrock, Holley and others sell port injection "systems" that ought to satisfy most needs.
RACE ON!!!
So there shouldnt be a problem putting it on there? Also, what about the computer if I change the engine to a 400? Thanks, Zak.
What about the 400 damper? Wasn't the stock damper too big to fit a C4 and the front cross member needed grinding and hammering? This is something I think I remember from the ancient times when still people did 383's with 400 bits.
If you don't tell the computer, I won't. With a mild, torque oriented, build, the computer won't need a thing.
I think you are getting ahead of yourself, here. This project is just in the exploratory stages; what can or can't be done. Just as adjustments would have to be made for some year variances, the 400 damper would have to be dealt with. You are right, it is too big and won't clear the cross member. Either the cross member would have to be modified or a specially balanced, smaller diameter, damper would have to be attained.
I am trying to keep this simple and basic, at this point.
