I just had the fluid in the rear changed, and now, practically every time from a stop, when I go into 1st, or Reverse, I get the ASR active. Is this normal, or is a sensor now whacked ?
Mine comes on if I hit something on the road when accelerating on a corner for instance. But never from just going from reverse or 1st with the auto unless the road is not clean of course.
I'll agree that something probably changed, but I'm not sure what it would be. I'm pretty sure the ASR uses the same wheel speed sensors as your ABS system, they shouldn't have been disturbed, strange indeed.
