A/C Compressor 1993 lt1 question
Old Dec 6, 2007 | 06:16 PM
freedog81's Avatar
freedog81
Default A/C Compressor 1993 lt1 question
Working on the road i purchased a A/C Compressor from ebay and it looked the identical in the picture. To make a long story short i get in last night and look it over, wake up this morning to install it and the bottom bolts are about a half inch too high on the bracket. I then take a closer look and realize i have a denso compressor that came off of the car and could have possibly purchased a Delco compressor. Is there anything that can be done to make it fit such as swapping brackets or do i just have to wait for a replacement? And what are the differences in the different years for the a/c compressors?
Old Dec 6, 2007 | 07:21 PM
SunCr's Avatar
SunCr
X-reference parts at www.acdelco.com - all of the late model C4's (except for the ZR1) use the Nippo 10PA20C. On the LT motors, the manifold is turned around and faces forward. I don't know of any other GM (or foreign for that matter) using this model #. As I said, x-reference at the Delco site, it will give you every vehicle that uses the same part.
