Bad switch?? HELP!!!
Old Dec 6, 2007 | 07:29 PM
machinegunminky's Avatar
machinegunminky
Default Bad switch?? HELP!!!
OK Im stumped....I have an '86 coupe. The ignition switch is malfunctioning. It started as an intermitent problem. The key turns the switch and all power comes on but it wont go all the way forward to engage the starter (into the springy part) It just stops and it wont start. Is it the switch or the rod that is in the column? Help!!
Old Dec 6, 2007 | 07:39 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Very probably the switch down on the colomn. On the C4, they use the old system where the key/lock asm. is not the ignition switch. There is a nut and 2 5/16" screws that hold it on. Once you take it off the key should move fine (if the switch is the problem).
Old Dec 6, 2007 | 08:00 PM
any4xx's Avatar
any4xx
And you might get lucky. If it has come loose, it might have slid down far enough that there isn't enough "key" movement to push the rod to the "Start" position. If so, you can just slide it back up the column and re-tighten the screws.
Old Dec 7, 2007 | 02:01 PM
machinegunminky
DONE DEAL!! ALL FIXED!!
Old Dec 7, 2007 | 03:01 PM
any4xx's Avatar
any4xx
So what was it?
To Bad switch?? HELP!!!
