service ride control light
Old Nov 23, 2001 | 04:26 PM
emoshn's Avatar
emoshn
Default service ride control light
My service ride control light keeps coming on...and now want s to stay on. Where do I start with this thing? 92.
Thanks Dave
Old Nov 23, 2001 | 06:03 PM
Ruby_Roadster's Avatar
Ruby_Roadster
Default Re: service ride control light (emoshn)
Firstly, with lots of $$. I had the same thing happen and went through all checking and replacement options before deciding what should be done - Shocks, Shock Tops, Actuators, SRC Module - turned out that it was a cheaper option to go with a specificy designed setup rather than try to get the FX3 repaired.
Now have Disconected the FX3, New Bilsteins with Coilovers, Removed Front & Rear Springs, Shocks setup for Road & Track with aggressive valving, can run street tyres or slicks, Lowered 1" - total cost over here came out at around $1,250US
Old Nov 23, 2001 | 06:49 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
You need the Helms manual! Run through the proceedure and check the codes and you will find what set the code. Not all that hard, and Bilstein will rebuild your shocks. You can also still get all the new FX3 shocks you want.
From what I have read on this forum, the usual problem involves and actuator gear or a failed shock.
Factory manual will walk you through it.
Good Luck,
Pete
BTW, anybody with take-off FX3 shocks, (I think pre 93 fit my 89?) lets talk. Better then chucking them. I would not mind having a couple sets to re-valve / swap. (been posting this for 3 years and nobody ever sells me FX3 shocks!)
Old Nov 26, 2001 | 08:24 PM
emoshn's Avatar
emoshn
Where can I get the Helms manual?
Old Nov 27, 2001 | 01:51 AM
Jay Axson's Avatar
Jay Axson
FX3 – Service Ride Control test (at least for 1992's)
To obtain codes, ground terminal C on the ALDL (Assembly Line Diagnostic Link). The ALDL can be found under the driver side dash.
The Service Ride Control light will blink. Each digit is read by counting the number of flashes. Each code is two digits and each digit will have a one second gap between them. Each code will repeat 3 times.
More than one code may be displayed. Each code sequence will start with a code 12. Code 12 is just a start of sequence indicator.
Code Definitions
12 = Start of sequence
13 = Left rear time out
14 = Right Front time out
21 = Left Front time out
22 = Right Rear time out
31 = Left Front out of position
32 = Right Front out of position
33 = Left Rear out of position
34 = Right Rear out of position
Out of position codes are triggered if the computer senses that the actuator has not found the end stop position on the shock. Remove actuator at the indicated shock. Turn the valve gear on the shock stops after about 3 / 4 of turn, then you have a bad actuator. If it spins around continuously then it is a bad shock
41 = Selective ride control switch short to voltage
42 = Selective ride control switch open contacts
You can have a code 42 if you leave the switch in between indented positions
43 = selective ride control switch circuit open.
I
To service ride control light
